cheese dreams...
You've probably seen the original 'Chuck Norris' list - well here are some new ones straight from the source document for all you Tactics guys. (Best ones in bold!)
Excerpt from CNTTP 3-69 (Chuck Norris Tactics, Techniques and Procedures)
(UNCLASS)
1) Chuck Norris executes a banzai gameplan regardless of awareness and AMR. Short-skate tactics are for the weak.
2) Chuck Norris is always in the “advantageous element.”
3) Chuck’s commit criteria is JFS Start. Mr. Norris doesn’t need avionics or a weapons system to be lethal.
4) Chuck Norris once had a wingman call a KIO for a PTO shaft failure. Chuck said he was “rejoining chase” and subsequently gunned the guy for being “worthless and weak”.
5) If Chuck Norris is conscious he’s inside your turn circle.
6) Chuck Norris does not jink. Under any circumstance. Period.
7) Chuck Norris once had a wingman go blind. Once.
8) Chuck once decapitated a SEFE for telling him he was in his 4th Month for a Mission Check.
9) If you’re an “W-Prefix” don’t let Chuck Norris get wind of it. If he does, QC your last will and testament
10) Chuck Norris doesn’t do SEAD. The word suppress is not in his vocabulary.
11) If Chuck Norris is airborne, ACM is one-role by his mere presence. There is no 2 vs 3-role argument.
12) If you fly with Chuck Norris, do yourself a favor and don’t brief a shot doctrine. As a matter of fact, don’t brief any contracts, except killing. On second thought, don’t brief that either. It’s assumed.
13) Chuck Norris’ right eye has 4 times the acuity of a Sniper Pod.
14) Need an EA plan? Try having Chuck Norris hum the 2nd verse of Metallica’s “Enter Sandman.”
15) Threat criteria . . . . . . not with Chuck!
16) Don’t use the term “Ten Chucks” during the adversary coord brief when Mr. Norris is around. He just doesn’t like it. Shortening AA-10D to “ducks” is fine.
17) Chuck Norris guides all LGBs with a standard Life Support issue fingerlight. It’s still unclear how he does it but he uses continuous lase as a general rule.
18) Chuck Norris refuses to do any GP delivery except a 90 degree DB, thus completely negating the need for CWDS. This attack should normally be flown as a direct pop.
20) JMEM weaponeering does not apply to anything employed by Chuck Norris. His normal SSPD is 1.4 regardless of target composition.
22) The F-pole of a Chuck Norris employed AMRAAM may vary by up to 6nm based on Chuck’s mood. Just something to consider when you “build your numbers.”
23) Chuck Norris was once told to “retrograde” by OCA escort when he was a striker. Chuck killed the entire blue OCA escort 4-ship, then banzai’d into 6 red-air groups inside FR. Since this took a few minutes, AWACs subsequently asked if he needed a TOT extension. Chuck kamikaze rammed the E-3 and proclaimed “Chuck Norris on guard, picture clean.”
24) Chuck Norris maintains the Link-16 network using an abacus, a 30-minute hourglass, and 8 two-way CB radios. That’s all you need to know.
25) Chuck Norris will be supersonic south of the Mormon Mesa whenever he wants.
26) Chuck Norris only operates under Type 3 CAS as Type 1 and 2 imply some reliance on someone else. Tomahawk FAC-As use caution.
27) Chuck Norris is the GLIB I.
28) Chuck Norris does not float, action, loft, crank, WEZ deny, take second shots, abort, or notch. I think you know why.
29) Chuck’s ownship position is always bullseye.
30) As a general ROT, Chuck Norris is able to VID at TR + 5, thus completely negating the need for a PID matrix.
31) Chuck’s MESL:
32) Chuck Norris dug Groom Lake by hand at the conclusion of the Vietnam War.
33) Chuck Norris’ controlled ejection altitude is -6 feet AGL.
34) Chuck Norris has never in his life been denied GPS acquisition.
35) Chuck Norris has never left anything to the RTO.
36) Ronnie did not leave the Tomahawks for a better “job opportunity.” He was killed by Chuck when he entered the wrong takeoff time into PEX for a Chuck Norris 4-ship.
37) Chuck Norris noise abatement procedures: 2 strafe passes with 20mm on anyone golfing on Shadow Creek’s 7th hole.
I am so pround that my thread turned into a Chuck Norris thread. Maybe I was Chuck Norris in my dream!
Chuck Norris would have lifted the plane himself, then slowly walked back to the gate setting the aircraft down nicely. He would have then used is mental powers to place chock, chains, and boots around all three landing gear. In an instant he would have been in the jetway escorting the elderly clear of the danger.
You Sir, could never be Chuck Norris.
> Chuck Norris
> Chuck Norris doesn't read books. He stares them down
> until he gets the information he wants.
> If you ask Chuck Norris what time it is, he always
> says, "Two seconds till."
> After you ask, "Two seconds till what?" he
> roundhouse kicks you in the face.
> Chuck Norris uses ribbed condoms inside out, so he
> gets the pleasure.
> Since 1940, the year Chuck Norris was born,
> roundhouse kick related deaths have increased 13,000
> percent.
> There are no disabled people. Only people who have
> met Chuck Norris.
> There is no chin behind Chuck Norris' beard. There
> is only another fist.
> It was once believed that Chuck Norris actually lost
> a fight to a pirate, but that is a lie, created by
> Chuck Norris himself to lure more pirates to him.
> Chuck Norris once lined up to kick the winning field
> goal of a high school football game. When the
> football went flat, he persuaded the referees to let
> him kick the field goal with a 3 month old child.
> Chuck roundhouse kicked the baby 60 yards through
> the uprights and then proceeded to bang every girl
> in the stadium.
> When Chuck Norris's wife burned the turkey one
> Thanksgiving, Chuck said, "Don't worry about it
> honey," and went into his backyard. He came back
> five minutes later with a live turkey, ate it whole,
> and when he threw it up a few seconds later it was
> fully cooked and came with cranberry sauce. When his
> wife asked him how he had done it, he gave her a
> roundhouse kick to the face and said, "Never
> question Chuck Norris."
> Those aren't credits that roll after Walker Texas
> Ranger; it is actually a list of people that Chuck
> Norris roundhouse kicked in the face that day.
> If you unscramble the letters in "Chuck Norris" you
> get "Huck corn, sir." That is why every fall, Chuck
> travels to Nebraska and burns the entire state down.
> Chuck Norris' tears cure cancer. Too bad he has
> never cried.
> Chuck Norris once roundhouse kicked someone so hard
> that his foot broke the speed of light, went back in
> time, and killed Amelia Earhart while she was flying
> over the Pacific Ocean.
> Rather than being birthed like a normal child, Chuck
> Norris instead decided to punch his way out of his
> mother's womb. Shortly thereafter he grew a beard.
> When Chuck Norris plays Oregon Trail his family does
> not die from cholera or dysentery, but rather
> roundhouse kicks to the face. He also requires no
> wagon, since he carries the oxen, axels, and buffalo
> meat on his back. He always makes it to Oregon
> before you.
> Chuck Norris built a time machine and went back in
> time to stop the JFK assassination. As Oswald shot,
> Chuck met all three bullets with his beard,
> deflecting them. JFK's head exploded out of sheer
> amazement.
> Chuck Norris sold his soul to the devil for his
> rugged good looks and unparalleled martial arts
> ability. Shortly after the transaction was
> finalized, Chuck roundhouse kicked the devil in the
> face and took his soul back. The devil, who
> appreciates irony, couldn't stay mad and admitted he
> should have seen it coming. They now play poker
> every second Wednesday of the month.
> A man once asked Chuck Norris if his real name is
> "Charles". Chuck Norris did not respond, he simply
> stared at him until he exploded.
> Chuck Norris recently had the idea to sell his urine
> as a canned beverage. We know this beverage as Red
> Bull.
> Chuck Norris can make a woman climax by simply
> pointing at her and saying "booya".
> Chuck Norris does not sleep. He waits.
> Chuck Norris once shot a German plane down with his
> finger, by yelling, "Bang!"
> The chief export of Chuck Norris is pain.
> After much debate, President Truman decided to drop
> the atomic bomb on Hiroshima rather than the
> alternative of sending Chuck Norris. His reasoning?
> It was more "humane".
> Chuck Norris often asks people to pull his finger.
> When they do, he roundhouses them in the abdomen.
> Then he farts.
> Chuck Norris is currently suing NBC, claiming Law
> and Order are trademarked names for his left and
> right legs.
> If you can see Chuck Norris, he can see you. If you
> can't see Chuck Norris you may be only seconds away
> from death.
> Chuck Norris took my virginity, and he will sure as
> hell take yours. If you're thinking to yourself,
> "That's impossible, I already lost my virginity."
> then you are dead wrong.
> Chuck Norris uses a live rattle snake for a condom.
> Aliens do exist. They're just waiting for Chuck
> Norris to die before they attack.
> Chuck Norris's girlfriend once asked him how much
> wood a woodchuck could chuck if a woodchuck could
> chuck wood. He then shouted, "HOW DARE YOU RHYME IN
> THE PRESENCE OF CHUCK NORRIS!" and ripped out her
> throat. Holding his girlfriend's bloody throat in
> his hand he bellowed, "Don't f--k with Chuck!" Two
> years and five months later he realized the irony of
> this statement and laughed so hard that anyone
> within a hundred mile radius of the blast went deaf.
> Chuck Norris appeared in the "Street Fighter II"
> video game, but was removed by Beta Testers because
> every button caused him to do a roundhouse kick.
> When asked bout this "glitch," Norris replied,
> "That's no glitch."
