Gatorman
Snot-nosed college boy!!
- Jul 24, 2003
- Total Time
- lots
I have a thrust reverser pig for ground operating the thrust reversers (no engine running)
Built for maintenance, you just hook the fitting in the pylon and fill the tank with 90 psi. Add ground power, arm the T/R and whollah, you have T/R actuation. Great for troubleshooting and especially fine for ops checks after installs.
http://www.shipitaogllc.com/gse/htm...erer%20Mule.JPG
With the right fitting (external start connection) I believe it will even start your engine!!!
GATOR
GATOR
