WMUSIGPI said:
Can a CFII log FOR IFR CURRENCY the approaches, tracking, and holding that the student does while in IMC?
No, no, a thousand times, no.
14 CFR 61.57(c)(1) is clear on this subject:
(c) Instrument experience. Except as provided in paragraph (e) of this section, no person may act as pilot in command under IFR or in weather conditions less than the minimums prescribed for VFR, unless within the preceding 6 calendar months, that person has:
(1) For the purpose of obtaining instrument experience in an aircraft (other than a glider), performed and logged under actual or simulated instrument conditions, either in flight in the appropriate category of aircraft for the instrument privileges sought or in a flight simulator or flight training device that is representative of the aircraft category for the instrument privileges sought --
(i) At least six instrument approaches;
(ii) Holding procedures; and
(iii) Intercepting and tracking courses through the use of navigation systems.
(emphasis added)
Clearly, the "performed" part of "performed and logged" means just that; you have to
perform the procedure in question. You have not
performed the procedure if your student flew it.
We had a Chief Pilot at FSI who tried to sell us instructors on counting our students' approaches and night takeoffs and landings as our own. He didn't get far. He was trying this con on us because he was too tight to let instructors have proficiency time.
The FAQs posted on an FAA web site and similar letters from FAA counsel are intended strictly for guidance. They are not black-letter law. In fact, the FAA operates something like the IRS. The IRS rules on each matter on a case-by-case basis, even though some cases appear to be identical. The IRS issues something called Private Letter Rulings, to which tax lawyers and accountants subscribe. Private Letter Rulings give you an idea which way the wind is blowing, but cannot be counted on as being dispositive of an issue.
Finally, consider it from a common-sense and safety perspective. Conceivably, under the assumption that an instrument instructor can count his/her students' approaches, an instructor who works in an IMC-rich environment could be regarded as instrument current without ever having his/her hands on the controls! That is
not the intent of this reg.
Hope this helps a little more.
