Cessna 152 or 172 for training?
Private cost
Cost will depend on four primary factors: (1) cost per hour of the airplane you fly; (2) cost per hour of your instructor; (3) weather, maintenance and aircraft availability; and (4) you.
I'll start with the last first. If you take instruction and criticism well, come to the airport prepared for each flight and are ready to learn, then you should do fine. Even the best students have trouble grasping some concepts. We all have our strengths and weaknesses, and you are no exception. But you should do fine if you are ready and willing to learn and take criticism. After being involved in athletics at a high level of participation, that should be no problem for you.
You can estimate the cost of training using factors (1) and (2). I suspect a 152 goes for $50 - $60 an hour. You will fly it at least 40 hours. Your instructor will charge something like $20 - $30 an hour. He/she will charge for ground time as well as flight time. Most people need more than forty hours for the Private. A lot of that depends on factors (3) and (4). Most people have to canx flights because of weather and mx at least a couple of times, and sometimes aircraft aren't always available. I already discussed (4).
If luck is with you and you can fly three or four times a week, you can get your Private in four to six weeks. Don't forget about ground school; it'll help if you can pass the written sooner rather than later. I had to stop while I was getting my Private to take the written.
Hope all this helps. Good luck with your training.
how about this
You guys talked about the size of the instructor that plays a factor in which plane I fly. Well I know one guy who is an instructor who I took a ride with who probably weighs about 140-150 lbs and is about 5'8"-5'10". How would that be in a 152? I would really like to start off in the 152, due to the cost, so maybe I'll just look for a light instructor.
If bucks are not a big problem, go with the 172 for all the reasons everybody has said, however, 210 lbs plus instructor weight will probably make the 152 out if the question anyway. Both airplanes are a joy to fly and learn in. Have fun a get out there.
It seems that some people are confused.
6'2"/175lb (the original poster) is just fine for a 150/152.
6'2"/210lb is also fine, depending on instructor weight, and how much fuel you take.
I'm 6'3" and (was) 175lb when I trained and instructed on 150's. Fitting in a 150 was never an issue. It's cozy but not really cramped. I actually used to enjoy flying the 150 more than the 172. When I spent a whole day in the air, however, I would often yearn for the relative comfort of a 172's bigger and softer seats.
I have always thought the 150 to be the superior trainer. WHY?
It is more demanding of smoothness from the student since it is more responsive. This responsiveness, in turn, leads the student to have a better "feel" for the airplane (which is what flying is all about, isn't it?). With regards to the 150 being easier to fly in gusty conditions: believe me, if you can land a 150 in a 15 knot crosswind component, you can land a 172 in the same. Finally, the little 150 is just plain more FUN. :D
Oilcanbland asked: "You guys talked about the size of the instructor that plays a factor in which plane I fly. Well I know one guy who is an instructor who I took a ride with who probably weighs about 140-150 lbs and is about 5'8"-5'10". How would that be in a 152?"
Absolutely fine at your weight and even a little more (you'll get full tanks too). The POH does a weight and balance at about 170lb for each occupant so you've got at least 340lbs to play with for the front seats (no that there's any back seats ;-)) and full fuel-of course you'll need to check the POH for your model to make sure.
Go the 150/52 you'll love it-it's a GREAT little plane. I'm buzzing around now in a 180hp 172RG and it feels like a bloody tank compared to the Sparrow.....
Matt
I just finished my PPL in a C152. I was wary at first..having flown a warrior on an intro. After the stability of a PA28, the 152 bomber felt like a mosquito in the gusts...but I must say VERY responsive. After a few hours in it, you will think you can make it do anything.
I love that little plane and recommend doing your training in it.
