Certification vs Operation
FOD said:
So say it is 40C outside and my performance charts only go to 35C and I took off, would I be breaking the Regs and operating outside of the limitations?
If the data also constitutes a limitation, yes. If the data does not constitute a limitation, no.
Ok maybe this is a dumb question, but how do you know if it "constitutes a limitation"?
avbug said:
Negative...minimum takeoff distances are limitations, reference Part 25. Balanced field lengths are not necessarily limitations, nor are many of the published takeoff distances. Be careful not to confuse published performance data with aircraft limitations.
Well I'm certainly confusing something, namely my overworked and underpaid brain.
Correct me if I'm wrong, but the wording in 25.1533 leads me to believe that the takeoff distance limitation includes the performance requirements of accelerate-stop, climb, etc.
The wording is "The minimum takeoff distances must be established as the distances at which compliance is shown with the applicable provisions of this part (including the provisions of §§25.109 and 25.113, for weights, altitudes, temperatures, wind components, runway surface conditions (dry and wet), and runway gradients) for smooth, hard-surfaced runways.
25.109 is accelerate stop, 25.113 is takeoff distance and takeoff run. So at the very least the takeoff distance limitation must include accelerate-stop, and it appears that "the applicable provisions" could be interpreted to include 25.111 takeoff flight path, 25.121 climb: one engine inoperative, etc.
Out of curiosity, I pulled out the A.F.M. for the ATR-42 (the only part 25 airplane I'm familiar with). The limitations section of the manual doesn't spell out anything about takeoff distance other than to say that "Performance Configuration - The aircraft configuration provided in section 6 must be observed". and "Maximum takeoff weight and maximum landing weight may be reduced by performance requirements related to the following (see chapter 6)" then goes on to list climb performance gradients, runway length, tyre speed, brake energy limit, obstacle clearance (takeoff and enroute) etc.
So this leads me to believe that the performance data in chapter 6 constitutes limitations, since they are explicitly reference in Chapter 2 (limitations). And the performance data in Chapter 6 (pages and pages of it), includes all kinds of graphs for every conceivable thing except a normal both engines operating takeoff. The "Takeoff Run" and "Takeoff Distance" graphs are both for "one engine feathered, one engine at R.T.O. power after critical engine failure - air conditioning off - anti-ice/deice off - no runway slope - no wind".
It's actually a pretty good question.
One way is pretty obvious: it appears in the Section 2 of the modern AFM - "Limitations." Quick example from even small aircraft. Is the weight and balance chart a limitation or advisory? Well, if you go to Section 2, you will see that the weight and CG limits are given there also. (Note ackattacker's most recent post about the Section 2 reference to the performance data).
Another is the TCDS (Type Certificate Data Sheet). Yup, you'll usually find the information there also.
A third is the certification rules themselves. As we've seen, some specifically say they are limitations; others don't. It's subpart G for both Part 23 and 25, you can put them side by side and see the differences. You'll see that the language making the takeoff performance dataa limitation that appears in Part 25 does not appear in Part 23.
One more. Perhaps not really a limitation in the technical sense, and may even be a little vague at times, but definitely one in a practical sense. (This one could probably be an entire thread by itself). Watch out for AFM operating instructions are given in mandatory terms. There is NTSB case law holding that doing things like skipping a checklist item violates 91.9. The problem here might be deciding what is mandatory and what is just informational (the famous C172 'slips with flaps' argument).
Most of the time, for most of us, it will be a combination of Section 2 with a dose of the "mandatory instruction" problem.
The chart is not where the limiation is found. The limitation you would violate is the one in the limitations section that says maximum temperature is 35C.
Midlifeflyer,
Your answer is much appreciated, this is something a faced a while back and always wondered about it. Thanks
But wouldnt i be breaking part 91 because i cant compute my takeoff and landing distance?
FOD said:
But wouldn't I be breaking part 91 because I cant compute my takeoff and landing distance?
In part, its one of those "is it mandatory" issue.
Here's what the regs say about it:
§ 91.103 Preflight action.
Each pilot in command shall, before beginning a flight, become familiar with all available information concerning that flight. This information must include -
(b) For any flight, runway lengths at airports of intended use, and the following takeoff and landing distance information:
(1) For civil aircraft for which an approved Airplane or Rotorcraft Flight Manual containing takeoff and landing distance data is required, the takeoff and landing distance data contained therein; and
(2) For civil aircraft other than those specified in paragraph (b)(1) of this section, other reliable information appropriate to the aircraft, relating to aircraft performance under expected values of airport elevation and runway slope, aircraft gross weight, and wind and temperature.
Assuming the data is not "defined" as a limitation, what happens when we're between (1) and (2); An required AFM that doesn't cover the situation? Do you have to make a no-go decision or can you rely on (2) to cover the difference.
My guess (and it's only a guess) is that you can use "other available information" to take up the slack if the data is not clearly a limitation. I'm saying that because of the "familiarity" language - way to casual to be read as "shall abide" or "must do." "Familiarity" at least to me, suggests that I may use the data as a starting point and apply reasonable principles and experience. At least I hope so: it's an issue we face pretty often flying in Colorado.
Not Exactly
avbug said:
The confusion is between certification standards, and operating rules. There is no correlation.
You must comply with published limitations. A performance chart shows what the aircraft can do under a specific set of circumstances, and one would be foolish not to avail one's self of that information if accurate...but it's not necessarily a limitation.
Weather the aircraft is certificated under Part 23 or Part 25 is largely irrelevant to how you operate it, as neither are operating rules. Both Parts 23 and 25 are standards which must be met by the aircraft in the certification process. What you do with it is up to you, within certain bounds.
I would hate to be in front of an Administrative Law Judge arguing this one. If you operate outside of the certification standards for an aircraft including performance data (which is principally what part 25 was devised for) and the FAA is going after you I can offer no legal defense except to advise you to try to settle for a Civil Penalty, before you get in front of a Judge.
