gunfyter
- Mar 25, 2002
Reality,
Your post sim NJA IPs teach the extra speed.
Then I had an IOE Capt that had me bring the speed back to the book numbers.
The extra speed helps with the roll and yaw as it can be hairy before you get used to the control feel on the older models especially. But after a certain number of hrs the extra speed is not necessary.
Touchdown at Vref or + you will tend to Bounce back up in the air as the landing attitude is approx same as t/o attitude. Touchdown at about ref -8 you will roll nicely down the rw. You will not float a long way down the rw if you come in at no faster than Vref... and touchdown a little slower to grease it on.
Wind gusts = possible wind shear to me. Ref+20 target speed. Reduce this speed after 200 AGL gradually to ref before TD. Don't reduce power to idle until you straighten the nose in the flair for touchdown or you will get a big surpris with loss of lift on the downwind wing.
