CE750 at NJA
Why is the 800xp the better plane to get? Better schedules, flying, airplane? What are some of the reasons for a potential new hire?
Pax like the speed. The typical flight ( if there is such a thing) has no more than 3 pax. Very comfortable. I have had 8 pax a few times, it does get a little tight back there.....but doable.
You think that is little tight, try 7 pax in the 400xp or hell even 3 pax is tight. Oh by the way on day 3 of 7. Second day of hot spare with no flying yet. But at least did not miss a playoff game this weekend.
I have seen guys land it, lets just say "different than me". Some of the guys "drive it onto the runway" without straightening the nose before landing (using rudder). I like to flare and use the rudder to land with the nose pointed down the runway.
Ski....I've been in the X for over 8.5 years, and what you just described is a real problem. I just finished IOE with a newhire who told me that FlightSafety is teaching to land it in a crab during a crosswind. WTFO?!!!
His first landing on our tour was in a x-wind, and hooboy, that was a wild ride. First, the mains touch down and immediately begin scrubbing as they're dragged partially sideways down the runway. Next the nosewheel follows the mains to the pavement and the vibrations get worse, plus the plane now immediately begins heading in the direction the wheels are pointed, ie. toward the side of the runway. Of course, now our newhire must quickly apply corrective rudder to keep from getting an up-close-and-personal with the runway edge lights. And in the panicked reaction, too much corrective rudder is applied and now we're swerving like a drunken sailor all over the runway. Somewhere in this mess the yaw damper kicks off (it's obviously not needed on the ground, but it takes a hell of a ride to knock that thing offline).
What's wrong with normal x-wind technique? You know, fly it in a crab on final. Straighten it out with rudder in the flare and LOWER THE UPWIND WING, and just set it down on the upwind main first, followed by the other and finally the nose, all the while tracking straight down the runway and increasing aileron into the wind. Basic airmanship.
And I don't want to hear anything about dragging a wingtip in the X. Puh-lease. It's easier to do than in other jets with less wing sweep, but it's not THAT easy to do. I've been using normal x-wind technique in this plane since I started flying it, and have yet to drag a wingtip. I teach everyone I'm instructing to do the same, and have yet to hear of any of them dragging a wingtip. In a normal landing flare you can use 8 or 9 degrees of bank without fear of hitting a wingtip (and that's A LOT of bank), although in all but the strongest x-winds I've never had to use more than a few degrees.
And while we're at it, what's wrong with crossing the numbers at 50 ft., power at idle, and AT REF SPEED!...........
Ski....I've been in the X for over 8.5 years, and what you just described is a real problem. I just finished IOE with a new hire who told me that Flight Safety is teaching to land it in a crab during a crosswind. WTFO?!!!
I'm sorry this post confused me. I have 0 time in a X and you obviously have a ton of time in a ten, so I am not trying to bust your balls. Isn't a crab the same technique that you described as your landing technique or did you mean FSI is teaching them to land with a side load, and then once on the ground correct the load. I know that this technique is used to prevent stalls and ground contact on balked landings in aircraft with swept wings and long spool up times as well as some wing mounted engine aircraft. Like I said, just wanting your input and clarification because of your experience.
cocknbull,
A crab is basically just allowing the plane to weathervane into the wind. Think about how a crab walks. So with the nose angled into the wind (say, a crosswind from the right) the plane would maintain a straight track toward the runway.
What you're transitioning into during the flare is forward slip (a side slip would be intentionally angling the nose into the wind using the rudder while lowering the downwind wing, commonly used to lose altitude rapidly in singles). A forward slip is keeping the nose aligned with the plane's intended ground track while preventing drift by lowering the upwind wing (or did I get those slips backwards?). It's been a while since I instructed those things (many many years).
But you're crabbing down final.
Hope that helps.
Just to play devil's advocate, the AFM does recommend the crab. It also says to allow it to land in a crab.
The AFM/FSI says: "The airplane should not be flown using the wing-down sideslip technique."
In a normal landing flare you can use 8 or 9 degrees of bank without fear of hitting a wingtip (and that's A LOT of bank).
Per the chart in the AFM....
At a normal landing AOA of 5 degrees you have approx 7 degrees of roll until wing strike.
Nothing.............if you like Carrier landings. :D
Of course, there is a difference in book/sim procedure and real world technique.
cocknbull,
Hope that helps.
Thanks, I see the difference crab through landing or crab till 50 feet then throw in the old slip.
Does the technique change with possible wind shear or large gusts, and do you guys have a correction to Vapp according to gust factor?
Nothing.............if you like Carrier landings. :D [/quote said:
lol i know that pulling the power back at 50ft in a "semenhole" will slam that sht to the ground
From my time in the X (3 years).
Yes the AFM says you can strike a wingtip with 5-7 degrees of bank during landing... with 10 pitch up. Normal deck angle for landing is nowhere near 10 dgrees pitch up. It's around 4-5 degrees. Add another few kts on apprach and over the fence (where it makes sense to have that luxury) and you have a nice stable approach with a lower deck angle (taking up a few hundred of extra feet).
To me, the above when not approaching a runway less than 5,500 feet was well within acceptable and confortable limits as opposed to dorking the runway down crooked in a gale crosswind on a contaminated runway at LGA at night just so I could forget to deploy the groundspoilers (manual) or land just plaiun hard, bouce up in the air and slam down hard, thereby creating a greater risk of wingtip strike in that now the rig is completely flying like a retarded emu.
Watch your deck angle and save the dork landings for SMO... that is the only place you will need them.
Try the dork method in SFO landing 28R and watch how fast the tower yells at you for holding up departures on 1L/1R.
NJACapt......Sorry, sometimes when making a point certain important details get left out, such as what the AFM actually recommends. Yes, I'm familiar with what's in the AFM. However, applying the recommended landing technique in a crosswind is a hairy ride. And I'll stick by my assertion that it's hard on the landing gear, as well as the pax and flight crew.
I've also made it a point to check the deck angle during the normal flair and touchdown. If you cross the numbers at REF, and don't keep holding it off forever trying for that perfect greaser, you'll touch down with a typical deck angle of between 5 and 7 degrees. At those deck angles you're perfectly safe with 8 degrees of bank, but as I mentioned before that is a very large amount of bank (right next to the ground) and rarely requires more than a couple degrees of bank for most crosswind conditions. And if it's a gusty crosswind, you'll be holding REF + a few knots, therby giving you an even shallower deck angle and therefore more leeway with lowering the upwind wing.
As for REF speed across the numbers with non-gusty winds, it works very well in this plane. Sorry, it's not a Seminole and bringing the power levers to idle will not cause it to suddenly drop or slam into the ground. In fact, generally speaking, in ground effect this thing likes to float. As for extra speed just for comfort, why? Oh sure, it's more stable and handles better at REF + 10, but it does even better at REF + 100. That doesn't make it the right speed to land at. I really don't care what the controllers at SFO say (BTW, never been yelled at by anyone for landing at the right speed), who's supposed to be flying this thing, the pilots or the controllers? Why is it a big deal to me? Because it forms bad habits. What I see A LOT of, is people always crossing the numbers at REF + 10 (or more!), which is all very well and good for those comfortable long runways, but when they are approaching a relatively short runway, they haven't practiced the right power settings for flying at REF across the numbers, nor are they ready for the slight decrease in roll control and tend to overcontrol the plane low to the ground (now I get worried about those wing strikes).
Landing at REF speed doesn't make for a carrier landing. I didn't say you had to jump on the brakes hard after touchdown. In fact, landing at REF speed means less need for extra braking and therefore less wear and tear on the plane, pax, and pilots.
Anyway, fly it however you like. I'll continue to teach it the best way I know how.
Reality,
Your post sim NJA IPs teach the extra speed.
Then I had an IOE Capt that had me bring the speed back to the book numbers.
The extra speed helps with the roll and yaw as it can be hairy before you get used to the control feel on the older models especially. But after a certain number of hrs the extra speed is not necessary.
Touchdown at Vref or + you will tend to Bounce back up in the air as the landing attitude is approx same as t/o attitude. Touchdown at about ref -8 you will roll nicely down the rw. You will not float a long way down the rw if you come in at no faster than Vref... and touchdown a little slower to grease it on.
Wind gusts = possible wind shear to me. Ref+20 target speed. Reduce this speed after 200 AGL gradually to ref before TD. Don't reduce power to idle until you straighten the nose in the flair for touchdown or you will get a big surpris with loss of lift on the downwind wing.
Gun......I agree with basically everything you said. Bottom line: under most conditions the extra speed simply isn't needed, and in fact can cause certain problems in the landing.
I agree about the post sim instructors. Man, are they afraid of this plane. I don't get it. I had X recurrent a few months ago and the sim instructors at FSI are starting to insist on seeing REF across the numbers. Good on them! But landing in a crab? They're still teaching that (yes, I know, it's in the AFM) and I still say it's not a good thing.
As for gust factors, I still prefer the old REF + 1/2 the gust factor method. Again, REF + 20 doesn't hurt anything at fields with long runways, but I landed at SMO one day with a quartering headwind and very gusty winds (gust factors of something like 15 knots). I flew at REF + 8 for the gust factor. Not sure I'd be terribly comfortable landing at SMO at REF + 20.
I believe you were my sim partner for a X recurrent. If I remember correctly you flew way better than most of the folks I've flown with (and better than me, but only by a little;) ), so perhaps I will defer to abilities beyond mine.
Remember the Alamo!
I HAVE been yelled at in SFO for just the very thing... one day while a X IOE guy was "showing me how to land the proper way" at SFO on 28R... at REF... of 106kts... stopping thousands of feet short of the 1L/1R intersection.
It was a beutiful 3 pronger ker splat... airplane hit hard due to a 20 kt gusty wind that gave up on us at 5 ft above the runway. REF plus.... (cough cough). SLAM!!!
Tried to tell him how SFO likes to run the show while on the arrival in. Eh, what did I know as a former 121 puke? I was only the Red Eye King back at Brand X for 3 years. SFO was my playground (no jokes here!!!;) ). 98.354% of the traffic that operates at SFO is of the heavier variety with a REF of 130-150ish. That is how they roll in their playground.
Sometimes you gotta play like the big kids at the playground... and at SFO, there is plenty of playground to land a bit fast, delay the reversers, roll past 1L/1R and turn off at D.
Come on Realityman... you remember.. doncha?!?!? :p
My only point is that there is a time and a place for literal SOP. Sometimes following SOP can lead you right into a mountain. Pilots gotta do pilot stuff sometimes!!
it prefer to go with my "feeling" when it comes to landings. I fly recommended approach speed(s) until i hit the fence then pull the power back, hold it in, etc. etc.. i just get a feel for the airplane and what it wants to do. i mean im no CJ driver like you folks..but i think what it all boils down to is...flying is flying... yes there are different number and sizes when it comes to a Seminole vs X..but when it comes down to stick and rudder...i think it goes back to your basic flying skills you've learned when you first got your commercial.
We at NJA really need a high speed approach profile. It kills me when I get with guys that pull back to ref+10 when we are lined up for 50+ miles to the runway. My God you don't need a 121 background to see how this will cause problems! Or maybe you do......
I must admit if fly the Uboat, I don't have the ego for the X:D. But regardless I see no reason to be going so damn slow before you get to 500 feet or so.
FLYLOW, crossing the numbers at REF speed doesn't mean you have to get on the brakes at SFO and come to a screeching halt in the first 2000 feet. I agree, that'll create a bit of friction with the controllers. But I hardly see how using the proper speeds on approach and landing, by themselves, would cause any problems.
I don't hear about our Ultra pilots being yelled at regularly by the SFO controllers, and the REF speeds of that plane are significantly slower than those of the X (I started in the Ultra, so I've got a pretty good idea what they are). A typical REF speed in the X is around 112-115kts. Typical in the Ultra is about 103. So if we need to fly the X at REF + 10 to keep the controllers happy at SFO, are you saying our Ultra boys need to cross the numbers at REF + 20, or more, to make them happy? That's a little out there. What's wrong with REF across the numbers, and then just idle reverse and light braking until passing the 1's at SFO? All good technique.
As for not always flying the SOP's and AFM numbers quite so literally all the time, I agree. Hence the reason I don't use the AFM recommended x-wind landing technique. I think it's dangerous and hard on the plane and everyone else.
Fozzy, who said anything about flying the approach at REF + 10 far from the runway. I think crossing the FAF and configured for landing would be a good time to slow to the proper approach speed, but that's typically only 5-8 miles from the runway. I'm not sure about maintaining high speeds until just a few miles from the runway though. Does slowing from REF + 40 to REF just 3 miles from the runway count as a stabilized approach?
Anyway, fly it like you know how. Different strokes for different folks. I expect as long as we don't ball one up, one technique is as good as another.
It looks like I hit a nerve on this one. All this talk about Ref speeds, bank angles and whatever else....who cares. All I was trying to say is straighten it out just before touchdown.
If I am flying into 28R at SFO, who cares if I cross the numbers at Ref+30. Now if I am going into SMO, I am going to get it slowed up.
I am not watching the amount of bank angle. I am FLYING. Remember, that is what we get paid to do, Fly the airplane.
My brief, "keep us off of headline news".
ski....what's wrong with discussing technique on an aviation forum? Obviously, I have ways I'd like to see it done, and others have ways they prefer to do it. We make our cases and others respond. It's called a "discussion".
As for flying the plane, I always thought being aware of speeds and bank angles and such in conditions where they are important was part of flying. Hey, I'm all for seat-of-the-pants flying. Heck, I've got two planes myself that are equipped only for basic VFR. Good fun! And no fancy instrumentation to help me with bank angles and speeds except for my eyeballs and an airspeed indicator that doesn't work very well.
But those aren't the planes I'm flying for work. I don't think anybody stares at the ADI or airspeed indicator through the flare and touchdown, but I have glanced down to find out what the typical deck angles are just prior to touchdown. In the X it can be important. It's nice to know how much bank angle I have to work with. A little knowledge and all that......
And I completely agree with you: straighten the doggone thing out before you touch down!
Its easy to land the X ... once you get used to it. But initially it made me feel like a new flight student going around the patch for the first time.
Many people find it a challenge at first. Not everyone but many. Its few people who don't get a Red Screen at least once in the sim on the V1 cut.
Again, I fly the ultra. And this is very easy. Hell you can be at ref+ a lot at 1000', pull to idle and be adding power to make the runway. I know that is not possible in the X
i agree, straighten the plane out before touchdown. Like my CFI instructor Frank Varsolona says, "dont land all cadiwhompas"
I agree that discussion is a good thing.
My other gripe is some (most) of these captains are really hard on the planes while taxiing. Jerky turns and braking. And they rarely follow the rampers directions.
Do you NJ guys/ gals ever do flap 15' for landing w/ strong gusty x-winds? Or does NJ not allow it? It seems to allow alot more rudder authority and flatter deck angle w/ only a 5-7 knt increase in ref. Our department uses it all the time if the runway length is allowable.
Just curious-
Just curious-
We just did a flaps 15 landing yesterday.......not for gusty winds though. We had a Hyd A low quantity, and had to blow the gear down. The emerg pneumatic brakes worked like a champ too! I think our ref speed was only 120....not a whole lot of difference from a full flaps landing. Lots of fun being towed off the runway!
