RampFreeze said:To clarify, the "Minimums" call from the GPWS is simply going to be heard at whatever height the RA bug is set at. It will be heard at either the DH or AH as appropriate. So, on a Cat IIIA/B-Land 3, with a 100' Alert Height (AH), you ignore the minimums call (since there are no minimums on this approach with an Alert Height vs. the RA Decision Height on a Cat II or Cat IIIA-Land 2 which does have "minimums" of ~50' AGL) We set the Cat II RA DH (~100') for a Cat IIIA/B-Land 3 (and get the "minimums" GPWS call) for a couple of reasons. 1) it is an advisory of reaching the alert height 2) in case of a malfunction restricting us to a Cat II approach, the bugs are already set. (We can hand-fly a Cat II as necessary and if you do end up hand-flying all of a sudden, the last thing you want to be doing is dialing the bug) If we revert from a Land 3 condition to a Land 2 condition, you just dial down the bug 50' and press. Clear as mud?
Gottcha. Just hace a hard time ignoring any minimums callouts and continuing on futher down to a lower altitude. Thanks!
