Carbon Cub Airplane Tire Jack
Sntry
Member
Hello All.
I do not have access to a ceiling lifting system (ceiling winch) to raise the airplane to install tires - 31 inch Bush. Seeking your recommendations and suggestions!
My initial attempt was using two - Powerbuilt 2 Ton UniJack Combination Hydraulic Bottle Jack / Jackstand in 1 Unit with one jack on each gear. Unfortunately, when I tried to place the tire, the jack was too close and had to move the jack inboard to the outer edge of the support making the installation a bit uncomfortable as the jack support bracket was on the very edge of the gear. Then, I used a combination of bottle jacks and floor jack but it was still really tight against the tire and at the edge of the gear frame. I don't need to reinvent this and simply need a safer and better method.
Would great appreciate your thoughts and suggestions. Jaime
