Can you descend below DH or MDA??
You will go below DH 100% of the time unless you have a JATO bottle.
No, you won't, Papps.
The correct answer here is, "It depends."
It depends on the type of equipment you are flying.
Little Cessna 172's can make an immediate transition from a descent to a climb with no readable descent below the DH. It is done every day in training, and most examiners will expect this type of pilot skill and response. in this type of airplane.
The airplane can do it. So the pilot should be able to do it in his demonstration of executing a timely missed approach.
Moving on to larger equipment, the big machines will take a little time to change direction of motion, and the amount of descent below DH that the examiner allows is dependent on his knowledge of the machine, and his observation of the moment of the pilots control inputs to execute the missed.
So..."it depends."
yeah this one has confused people forever. If your in jet doing 140 knots on final and 700-800 fpm to hold glide slope. The pilot not flying will call "minimums no runway" right at DH. In the rj you will say hit the TOGA button push the levers up and say "go around go around thrust flaps 8" and pitch up to the Flight director. The plane will be below DH by the time you start uphill again. And no check airman on earth will fail you for that.
Good discussion that never hurts to be rehashed. You may even touch down on the runway on the runway if you're flying a Cat III missed approach.
LS
You may even touch down ... on the runway if you're flying a Cat III missed approach.
LS
Lead, Good point!
I would like to add: With the appropriate aircraft (read large/long), appropriate runway (CAT III certified), approved procedures, and approved training program. (small print at the bottom of the screen" "Trained Professionals used in this ad, don't try this with out one".)
With the right conditions (low, solid overcast) in the right aircraft (DC 10, 747, etc.) the pilot can decide at DH to conduct a missed approach, have the wheels touch the runway, and go missed approach with out ever seeing the runway. Legal and safe under the above conditions.
DH - The height you make a decision.
MDA - The MINIMUM Descent Altitude.
JAFI
JAFI
And there it is in a nutshell, folks.
Isn't it amazing that something that simple and obvious still is misunderstood by folks who should know better?
So..."it depends."
I disagree. The regs state nothing about "little planes shouldn't go below DH during the execution of a missed, but big airplanes can." DH is just that - a place where you decide to go missed or continue the approach. If you start the missed approach at DH in a 172 and go below DH while transitioning to a climb, then that is fine. DH is not MDA.
Guys, the point I am trying to make is, if you are in a 172, and you let the wheels drag the runway during your missed approach, or go down an appreciable amount, like you could in a Cat III in a heavy jet, I don't think an examiner will allow that on a checkride, or an inspector would agree that you can take as long as you want to, to "effect a pitch and power change that would result in a timely transition to a climb."
We are talking about timely control inputs. If you make the same pitch and power change at DH, the 172 will perk up and fly up within 20 feet, the heavier it is the longer it goes down before changing when the control inputs are the same. That is what we mean about "it depends".
Not to split hairs, but a C172 would be using a DA (unless, of course, it has an RA installed and was shooting a CAT III.) :eek:
I guess what im saying is that you don't understand the theory behind DH/DA. Just because a 172 weights nothing, and will get up and go before its caveman era altimeter registers a descent below DH doesn't mean you understand what DH is.
And if you let the wheels drag the runway on the missed in a 172 you either didn't make a decision at DH, or that decision took you 5 minutes to make.
Your right, this is more of a big plane deal, but unless you want to spend your entire career in the C-172 you will want to learn what DH is and isn't
Well said Papps. You can teach a student pilot how to fly a C-172 or how to fly an airplane. There is a difference between the two concepts. If you teach how to fly airplanes the lessons will carry over to the 172 because it is an airplane. If you teach people how to fly a 172 the lessons will not necessarily carry over to larger, more complex airplanes. You also end up having to have threads like this to sort things out.
LS
Some of you guys need to go back and review physics 101. If you make the decision to go around at the DA/DH, you will always go below that altitude, it doesn't matter if you are in an A380 or a friggin ultraight. Its something called, umm, oh, lemesee... inertia.
...and so you went 20' below the DA/DH. The little airplane still has some amount of inertial and cannot react instantaneously. For that matter neither can any of you SH pilots out there. As expected and allowed in the regs as others have already pointed out.
Fly safe,
265
:beer:
For the misinformed still out there, I happened across this. ​
Section 4 of the AIM (Arrival Procedures)​
4. Chart Terminology
(a) Decision Altitude (DA) replaces the familiar term Decision Height (DH). DA conforms to the international convention where altitudes relate to MSL and heights relate to AGL. DA will eventually be published for other types of instrument approach procedures with vertical guidance, as well. DA indicates to the pilot that the published descent profile is flown to the DA (MSL), where a missed approach will be initiated if visual references for landing are not established. Obstacle clearance is provided to allow a momentary descent below DA while transitioning from the final approach to the missed approach. The aircraft is expected to follow the missed instructions while continuing along the published final approach course to at least the published runway threshold waypoint or MAP (if not at the threshold) before executing any turns. ​
I was reading the requirements for descending lower than the DH and MDA, am I correct to assume you must have:
1) Stabilized approach
I don't think this is a reg at all, but company policy about when you have to be stabilized or not.
2) Runway enviornment in sight
No. On an ILS you can have the approach lights in site at 200' AGL and continue. At 100' you need to have the runway lights/environment in site to continue.
3) Visibility greater than published for the approach
No. You have to have this visibility prior to the FAF, or whenever the final segment of the approach starts. If the reported vis goes down after this, you can continue the approach. You do have to have the "Flight Visibility" at DH/MDA, but not the "Published Visibility".
Also, you can leave MDA (and this applies to the DH also) to land when you have the runway environment in site, but you may later lose site, as in going into a thick cloud, and you may then have to go around at that time. In this case, in a C-172, your gear MAY hit the runway during the go around.
Correct me if I am wrong........
cliff
ABQ
There is a requirement that you have to ba able to get tot he runnwasy using normena descent rates and manuvers. This isn't the same as a stabilized approach but it's probably where the confusion starts.
Actually, you may do the same on a non-precision approach also, although without vertical guidance there is more opportunity for screwing it up , as the guys in the Jetstream at Kirksville found out.
Well, actually, his answer is correct, although it is useful to clarify that it's flight visibility you must have to descend below MDA, not reported visibility.
Requiring visibility to proceed past the FAF is a 121 thing, andh the question was a general one. That doesn't make it incorrect, but it should be noted that under part 91 only, there is no visibility requirement to begin an or continue an approach past the FAF. You make a distinction between "flight" visibility and "published" visibility which at best is confusing. The "published" visibility is the minimum visibility for the approach. To descend below the MDA or continue below DA, the "flight" visibility must be at or above the published minimum. To proceed past the FAF (or to even begin the approach under part 135) the "reported" visibility must be at or above the published minimum. "reported" visibility is used becuse obviously you can't determine flight visibility at the airport from 5-10 miles away, unless you can see the airport from there in which case visibility probably isn't a big issue.
That's good. in fact it is spot-on, and doesn't leave a lot of room for argument. However. I'm suspect that it isn't going to change some minds. I suspect that the reaction even if not posted is going to be something along the lines of:
I don't care what the TERPS says or what the AIM says, or what the regulations say, or what you guys who do this for a living say! I was taught XX decades ago that you never descend below DH/DA so G0ddamnit, that's what I'm going to teach to my students!!!
Sad when someone gets so set in their ways that they lose the ability to consider that thier way may be incorrect.
