Calculating VDP
When the runway is visible under the -3 degree line on your HUD, pitch down and put the flight path vector over the end of the runway. No Brainer.;)
Unfortunately, there's too many people that make this job harder than it needs to be, ie. people that worry about calculating VDP. Except for checkrides and line checks.
Amish in your example VDP is 2 miles from MAP is only true if the MAP is at the end of the runway. VDPs have nothing to do with MAP they are a calculation for reaching the Threshold at 50' HAT. I am sure you meant that but I just wanted to clarify. All your other poop was spot on.
Frieght dog try your 1.3 on the SLC VOR 17? I think you might miss that app.
