And more...
14.2.1.2.6.8. In many cases, the minimum visibility required for the approach will not allow you to see the runway environment until you are beyond the VDP. This accentuates the need to compute a VDP and determine a point along the approach when you will no longer attempt to continue for a landing. A common error is to establish a high descent rate once the runway environment is in sight. This can go unnoticed during an approach without visual glide path guidance and may lead to a short and/or hard landing. Caution should also be used to avoid accepting a long touchdown and landing roll.
6.8. Calculating a Visual Descent Point (VDP). The first step to computing a VDP is to divide the Height Above Touchdown (HAT) from your approach procedure by your desired descent gradient. Most pilots use a 3° (300 feet/NM) glidepath for landing. Here’s the formula to use:
HAT / Gradient (normally 300) = VDP in NM from end of runway
6.8.1. Now that you know how far the VDP is from the end of the runway, you may add this distance to the DME at the end of the runway to get a DME for your VDP. Armed with this information, it is easy to compute the distance from the FAF to the VDP. This distance is important in computing the climb gradient necessary for final approach.
6.8.2. Using the FAF altitude, the MDA, and the distance from the FAF to the VDP, you can compute a descent gradient from the FAF to the VDP along with a target VVI to ensure you are meeting the desired descent gradient.
Example: Use the following information to determine the descent gradient from the FAF to the
VDP:
HAT = 420 feet, MDA = 840 feet MSL, DME at the end of the runway = 0.5 DME, FAF =
6 DME, FAF altitude = 2,500 feet MSL, desired landing gradient = 300 feet/NM, Approach
airspeed = 150 KTAS, no wind.
VDP = HAT/Gradient =420/300 = 1.4
VDP DME = DME at end of runway + VDP distance = 0.5 DME + 1.4 DME = 1.9 DME
Descent Distance = FAF DME - VDP DME = 6.0 DME - 1.9 DME = 4.1 DME
Altitude to lose = FAF altitude - MDA = 2500 - 840 = 1,660 feet
Descent Gradient = altitude to lose / distance = 1660 / 4.1 = 405 feet/NM (4° descent gradient)
VVI = Angle (NM/MIN X 100) = 4 (2.5 X 100) = 1,000 feet/MIN
6.8.3. With this information you can depart the FAF maintaining a 4° descent gradient (400 feet/NM).
Your target VVI is 1,000 FEET/MIN. Each mile you should lose 400 feet. At 5 DME, you should be at
2,100 feet, at 4 DME, 1,700 feet, etc . . . Continue this descent gradient until reaching VDP at 840 feet
MSL. Hopefully, at the VDP, you’ll have the runway in sight. Adjust your descent to a 300 feet/NM
gradient and pick up your normal aim point.
Amish in your example VDP is 2 miles from MAP is only true if the MAP is at the end of the runway. VDPs have nothing to do with MAP they are a calculation for reaching the Threshold at 50' HAT. I am sure you meant that but I just wanted to clarify. All your other poop was spot on.
Just fly a CANPA and be done with it. Never liked dive'n'drive.
Alright, thanks guys. This may be a stupid question but what is CANPA? I feel like keel hauling my CFII!
1.3 miles from the end of the runway, works fer just about all of them.
Try it you'll see.
Hate to be "that guy," but the VDP will always be published on the chart. If no VDP is published, a PDP (Planned Descent Point) is what you calculate in leau of a VDP.
They work exactly the same, with the following distinction:
VDP = published
PDP = calculated by pilot
If no VDP is published, I always calculate a PDP: Just a good habit to get into.
Dude, I'm sorry the only job available to you is in that Douglasaurus firetrap..
Those approaches you linked are visuals,
Hey, now there's something fresh and new: If you don't have anything intellegent to say, toss out some completely unrelated insults. Wow, nobody on Flightinfo has ever thought of that before. An original thinker and a class act to boot, a real double threat kind of intellect.
Well, actually, no, they are not, they're just examples of approaches with high hat's, some of the many approaches where your "Just use 1.3, dude" strategy isn't going to work really well, or at all. I picked a couple with fairly extreme MDA's, thinking you could follow the logic, but I guess I overestimated your capabilities rather badly. I suppose that's my fault for not recognizing that someone who interrupts a discussion of calculating PDPs with "just use 1.3, dude" probably isn't the sharpest crayon in the box. My apologies.
In deference to your limitations, I'll post a couple more approaches, these a little less extreme, in which your "just use 1.3, dude" advice won't work very well.
http://www.naco.faa.gov/d-tpp/0706/01253G14.PDF
hat is 739', which would give a PDP 2.3 NM from the threshold, You'd be about a mile off with "just use 1.3, dude"
http://www.naco.faa.gov/d-tpp/0706/10059R7.PDF
on this one, hat is 861, which would give a 2.7 nm PDP, over twice the distance you'd get with "just use 1.3, dewd"
Here's another:
http://www.naco.faa.gov/d-tpp/0706/09297R13.PDF
Hat on this one is 1005'. PDP would be 3.2, which is a long way off from "just use 1.3, dewd".
These are just a couple that I grabbed from the back of my jepps. I could list dozens here in Alaska with hat's high enough that "just use 1.3, dude", wouldn't work. It's not just Alaska, either. There's hundreds of similar examples in the west, northwest, and the hilly parts of the southeast and northeast. The fact is, unless your flying is restricted to FLorida, or Kansas, or some other really flat state, "just use 1.3, dewd" isn't going to work a significant percentage of the time.
All your approaches have a common thread-They're in Alaska, with mountainous terrain, My original post said it works for most of them, and most of them got HAT's around 400 ft.
As far as not being "the sharpest crayon in the box", I've flown NDB approaches from Medellin to Mumbai.
So, if you think that having been to Mumbai and Medellin proves that you're intelligent, you're probably not the sharpest crayon in the box.
