furloughed 80, man I would check on that application and make sure there is not a problem with it, or check with the guys that gave you a rec and have them make sure that someone has seen it. If you've met the requirements and have good internal rec's like you said, there is no reason why you havent gotten a call, unless there is some other problem. I was in the same boat, not getting a call. Someone checked it out for me. Turns out my name was not showing up as having any rec's, even though I had 3. Problem fixed, got a call 3 weeks later. Best of luck buddy
