WMUchickenhawk
- Jul 12, 2005
- Total Time
- 900
In a Cessna 172 are the magnetos driven by the engine? I say they arent, but a friend says they are. Who is right?
WMUchickenhawk said:If they are driven by the engine, how do they work if the engine quits?
I was thinking backwards, I was thinking alternator. Just messed up my logic. Whats the point of magnetos if you dont have an engine working anyways. Thanks for the good replies, that cleared it up. and yours too bugchaser.NYCPilot said:They don't.
WMUchickenhawk said:I was thinking backwards, I was thinking alternator. Just messed up my logic. Whats the point of magnetos if you dont have an engine working anyways. Thanks for the good replies, that cleared it up. and yours too bugchaser.
Pedro said:If the prop stops moving then the magnetos stop working too.
Wrong. You forgot MONEY.Geronimo4497 said:Fuel, air and spark. That is all you need to make a piston engine run.
GravityHater said:Aha! His suspicion was right!!!... it's the prop that drives the magnetos!
Or is that magnetoes? Tomatoes Tomatos; Potatos Potatoes? Dang. Anyway.. I need to get back to my wine.
Lead Sled said:Wrong. You forgot MONEY.
'Sled
Pedro said:No, the prop doesn't drive the magnetos, the engine does, and also drives the prop. If the propstops turning is an indication that the engine stopped turning, which is alsoavery goodindication that the magnetos stopped turning.
Back to your wine!
NYCPilot said:Here's some trivial information about your engine too.
Engine designations might be something like IO-360, O-320 and so on. You might have wondered what these numbers and letters represented.
I = Injected
O = Opposed (as in horizontally opposed cylinders)
360 = 360 cubic inch displacement
Also, if you take half that figure, you'll get an approximation of the HP of the engine.
360 = 180 HP
320 = 160 HP
