Best aircraft for $14 million?
Bullitt
McQueen is THE MAN
Hi guys,
I've searched the archives extensively but I wanted to get some new info from the experienced guys. The boss is looking to move up from a Hawker 700. The budget he set is 14 million. Right now we are based in DTO with a 6000 ft rwy and summertime temps of 34C+ and the elev at 640msl. Typical trips are DTO-MMU-DTO and DTO-SMF-DTO with 5 people and bags. He has expressed a strong desire in a new G150. The G150 has some strong points but it looks to be a bit of a runway hog considering where we are based. I like the numbers on the Sovereign, but I think the asking price would be a little outside our budget. Based on the info above, what are some good suggestions on aircraft that would fit our mission profile? Thanks in advance guys!
You're not going to touch a Sovereign in this market for $14mm. A 601-3Aer might be a good choice, but I would need to know more about your missoion. If you're serious about buying an airplane, PM me and I can run some numbers for you.
The G-150 is a has been.....I can back this statement up based upon a meeting with Brian Moss. One of the problems is that if the crap hits the fan in Israel (which it's going to do), most parts are going to be unavailable.
Isn't the G200 built over there, too?
Another thing to look at is how long has he been in the Hawker, and the company growth forecast over the next 5 years. You don't want to buy a plane that will work now, but not in 2 years. The Sovereign is a very impressive aircraft with good support.
Run the numbers for a new Hawker 850XP. It is in the price range you are looking at. It does have better preformance than your 700. Good luck.
Hey guys I really appreciate all the quick replies! Good suggestions, keep em coming :)
Perhaps the Citation XLS
Elevation=1000ft
Temp= 35c
Weight= 20,200lbs (MTOW)
Flaps=15
Take off field length= 4,650ft
Just sold a Sovereign (one year old with 500 hours for $15.5 Million). Nice aircraft. I looked at a G-150 the other day on the ramp. It has rubber deice boots that are painted silver to look like it has a real hot wing. LOL! Get the Hawker 850XP if that is all you can afford (TKS is better than de-ice boots on a jet). The Sovereign would be better because it has a large baggage compartment (un-pressurized but heated), but you can't afford a used one on that budget.
How about the new Hawker900xp. This aircraft is the same as the 850xp but with bigger engines and better numbers than the 850xp. I believe it is in the same price range that you are looking at. Better range and will climb straight to 410 at max gross weight with no problem.
