uwochris
Flightinfo's sexiest user
- Dec 21, 2001
Hey guys,
I have another question in regards to engine failures in multi engine a/c. My previous post (in regards to sideslipping caused by the engine failure) was helpful, however, after doing some more reading, I have developed another confusion.
Let's say that you are flying in a twin with counter rotating props, and the right engine quits.
The initial tendency would be yaw in the direction of the failed engine; this will cause a sideslip, as the a/c will momentarily continue in its initial direction of flight.
In this case, left rudder will be needed. This will prevent some of the yaw, but it will not eliminate the sideslip.
My question is: why must we bank towards the good engine?
Is not the force produced by the rudder sufficient to balance the asymetric thrust and adverse yaw?
I know that you must bank to elminate the sideslip; the bank produces a force which will balance the force produced by the rudder; however, I thought the rudder force already balanced the asymetric thrust forces. If this is the case, it seems that all forces are already balanced, and thus, no need for bank. Obviously this is wrong, but I do not see why.
Also, why is it that when sideslipping with both engines operating, you must use rudder and bank in opposite senses? ie) force of the rudder will be balanced by the force of the opposite bank? In this case (multi engine a/c with 1 engine inop), you use rudder and bank in the *same* direction. This is why I am confused- using them in the same direction seems that an unbalanced force will be produced in the direction of bank.
Well, I hope someone can clarify this misunderstanding for me.
Thanks in advance,
Chris.
Thanks in advance,
Chris.
