BA 747 crew commended for escaping near-stall on take-off
Are all you tools F'ing kidding? HE GOT A REVERSE UNLOCK LIGHT AT 125kts!!!!!!!!!!!
ABORT! ABORT! ABORT!
They put themselves in the stall that could be avoided.
Good point, reading that in the update raised my eyebrow. 25kts below V-1, 14000' runway, problem with a thrust reverser..........
Better to be on the ground wishing you were flying than to be flying wishing you were on the ground.
Do you talking heads have any clue what you are talking about?
Do you know what the indication would be?
Do you know what an "unlock" indication means?
Do you know understand the problem?
Do you understand the probable outcome of a high-speed reject near gross in a whale?
Educate yourself before putting your DC-9 mouth into gear.
Gotta love all of the Monday morning quarter-backing on this situation and every other one that comes up regardless of outcome!!
Not in a Boeing.
One rejects a takeoff, and aborts an engine start. You don't know that?
You probably don't know enough to be second guessing the crew, either.
I'm not second guessing, I flew the 74 25 years ago and flat don't remember the significance of the warning. The Boeings I fly now don't display a warning during the takeoff role unless it's important enough to rejsct for.
Reverser unlocked sounds worthy of consideration, but I really don't remember.
Sully was in the left seat, in command, and best to try to get back to LGA visually. The FO was unable to see anything in their left bank back. Of course you would take control. Letting the flying pilot continue flying works best in most situations but not if he is new and on the outside of the turn back with no engines. Since they couldn't safely land downwind at LGA they landed in the Hudson. The FO might have done the same thing but was in the wrong seat to plan the ditching.
Yeah....with a 300-hour "diversity" F/O, like United Airlines, would have been a fireball.....
Papaa but Colgan was a Caucasian? How can that be? You foo oops! I can't say that.
EICAS message, just like the summary said?
Sleeve somewhere between stowed and extended.
Yes/No/Maybe. Good enough reason to abort (reject if you want to make up a story about how it happened to you and spout shi)
Probably better than continuing with one engine in reverse when you're high, hot and humid.
So educate me. How much runway does a "whale" near gross weight need to get from 125kts to 167kts on 3 engines and one in reverse at T/O power?
What's the big deal? He got the shaker, and unlike the Colgan 3407 crew, he lowered the nose (pushed down on yoke), gained airspeed, until stick shaker went away and airplane climbed. This is what common sense would dictate, what else are you suppose to do when the shaker goes off. I guess I commend this crew, but they only did what any competent pilot should have done.
Unfortunately that has become the new standard. NOT doing what the Colgan crew did makes you a hero. But I'm not complaining. A little good public attention for flight crews doesn't hurt.
Not 100% sure but I believe on the 747-400 that if the auto throttles are engaged, any indication of thrust reverser unlock will auto-retard and idle the applicable throttle. In that scenario, you'd have 3 good engines producing power, 1 engine at idle in reverse. Pretty sure it will fly just fine like that, but again, I haven't flown the whale.
Now it depends what EICAS indicated whether I'd choose to try to abort a takeoff above 100 kts. My normal brief includes, "Abort for anything under 100 kts, above 100 kts we're only aborting for an engine failure, engine fire, loss of directional control, or inadvertent thrust reverser deployment". However, that's in a two-engine aircraft where a thrust reverser deployment is pretty nasty business above V1.
If it was just a momentary EICAS message that disappeared right after I looked at it with NO indication in the directional control of the airplane to accompany it? I might not reject the takeoff, either. Accompanied by directional control issue (confirmation of an actual T/R deployment), yeah, under V1, I'm rejecting, but that's me.
But I'm not Monday Morning Quarterbacking a successful outcome of the maneuver, that's for sure. They made it work, good for them.
I profusely apologise to the BA crew for not acknowledging your superior airman-ship and decision making in your Joberg departure on my first post. Well done. If I ever have the pleasure of meeting either of you around the world, the night is one me. An awesome display of airman ship.
Needles to say, I am impressed.
Mr Wu, If you had asked, rather than attacked a crew that actually accomplished an amazing feat, I would explain. Right now the level of contempt I have for you and the others on this board that have the ignorance to question such an event speaks volumes about you. Good luck in your career. My only fear is that I have to position on an aircraft that you are in a front window seat of.
Save your whining for someone who cares. You answered my question - you don't know.
Negative.
Then what makes you "pretty sure?"
Not even the performance programs or charts will tell you this, as it's nonsensical. It's also irrelevant, as in the case in question, an engine was not in reverse at takeoff power.
The QRH procedure, which is not a memory item, for a reverser unlocked in the -400, is as follows:
Condition: REV annunciation displayed with reverse thrust not intentionally selected.
With no yaw, loss of airspeed, or buffet:
--Operate engine normally.
With yaw, loss of airspeed, or buffet:
--Fuel Control Switch, affected engine: CUTOFF
--Transponder Mode Selector: TA ONLY
Do not accomplish the following checklist:
--Engine Shutdown
Buffet may be reduced by decreasing airspeed.
Landing Preparation:
--Use Flaps 25 and Vref30 + 20 for landing.
Imagine that. Operate normally, with no yaw, loss of airspeed, or buffet. Do not shut down engine or follow engine shutdown checklist. Go figure.
Now, several here have lambasted the crew for not pitching to the stick shaker. The airplane was already there. Several have thrown in their "I woulda done this," or "I woulda done that" two cents worth, with obviously no Boeing experience, and certainly no 747 experience. The crew did what they could, given the circumstances. The crew did not have an engine in reverse, and didn't have an engine in reverse at full power. The sky is not falling, and the boogie man hasn't come out of the dark staircase just yet. The crew had a very unusual issue with which to deal, and they dealt with it well.
As for a rejected takeoff in the 747...http://2.bp.blogspot.com/_zjtdEB0M1...pUfk/s1600-h/KalittaN704CK-BRU080525-AAIU.jpg
A loaded takeoff the the 747 means you'll be seeing the red lights at the far end when you rotate, most places you go. There are very few indications that merit rejecting (not aborting) a takeoff. A reverser indication without yaw, loss of speed, or buffet isn't necessarily worth a high speed rejected takeoff.
Verbatim from AOM Volume II:
The thrust reversers are protected against deploying inadvertantly. If a reverser unlocks and deploys inadvertantly, the reverser system applies bleed air to stow and lock the reverser.
Good post Avbug. The bottom line is, anytime you second guess someone you usually are at least half wrong. They and Sully/Skiles both did a great job, period.
Boeing Certification and several years of command on the 727.
Would imagine it would be difficult to obtain certification if the aircraft was NOT flyable with 3 good engines and one in reverse... but thanks for asking. :/
1st warning.
Do NOT discuss East/West issues in anything but an East/West thread. Period.
The next infraction results in a suspension for 7 days.
/mod
1st warning.
/mod
But we're both so self absorbed...isn't EVERYTHING about us?;)
So you really have no idea, and are applying guesswork. Got it.
Which segment climb gradient criterion applies three engines with one in reverse?
Boeing certifies to Part 25. The certification standard for the 747-400 is Part 25, reference the Type Certificate Data Sheet: http://www.airweb.faa.gov/Regulator...B53BDC83FBC4DA6E862576B1007071F4?OpenDocument
In which part of 14 CFR 25.121 do you find a requirement to climb on three engines with a fourth in reverse, to meet certification standards?
§ 25.121 Climb: One-engine-inoperative.
(a) Takeoff; landing gear extended. In the critical takeoff configuration existing along the flight path (between the points at which the airplane reaches V LOFand at which the landing gear is fully retracted) and in the configuration used in §25.111 but without ground effect, the steady gradient of climb must be positive for two-engine airplanes, and not less than 0.3 percent for three-engine airplanes or 0.5 percent for four-engine airplanes, at V LOFand with—
(1) The critical engine inoperative and the remaining engines at the power or thrust available when retraction of the landing gear is begun in accordance with §25.111 unless there is a more critical power operating condition existing later along the flight path but before the point at which the landing gear is fully retracted; and
(2) The weight equal to the weight existing when retraction of the landing gear is begun, determined under §25.111.
(b) Takeoff; landing gear retracted. In the takeoff configuration existing at the point of the flight path at which the landing gear is fully retracted, and in the configuration used in §25.111 but without ground effect:
(1) The steady gradient of climb may not be less than 2.4 percent for two-engine airplanes, 2.7 percent for three-engine airplanes, and 3.0 percent for four-engine airplanes, at V2with:
(i) The critical engine inoperative, the remaining engines at the takeoff power or thrust available at the time the landing gear is fully retracted, determined under §25.111, unless there is a more critical power operating condition existing later along the flight path but before the point where the airplane reaches a height of 400 feet above the takeoff surface; and
(ii) The weight equal to the weight existing when the airplane's landing gear is fully retracted, determined under §25.111.
(2) The requirements of paragraph (b)(1) of this section must be met:
(i) In non-icing conditions; and
(ii) In icing conditions with the takeoff ice accretion defined in appendix C, if in the configuration of §25.121(b) with the takeoff ice accretion:
(A) The stall speed at maximum takeoff weight exceeds that in non-icing conditions by more than the greater of 3 knots CAS or 3 percent of VSR; or
(B) The degradation of the gradient of climb determined in accordance with §25.121(b) is greater than one-half of the applicable actual-to-net takeoff flight path gradient reduction defined in §25.115(b).
(c) Final takeoff. In the en route configuration at the end of the takeoff path determined in accordance with §25.111:
(1) The steady gradient of climb may not be less than 1.2 percent for two-engine airplanes, 1.5 percent for three-engine airplanes, and 1.7 percent for four-engine airplanes, at VFTOwith—
(i) The critical engine inoperative and the remaining engines at the available maximum continuous power or thrust; and
(ii) The weight equal to the weight existing at the end of the takeoff path, determined under §25.111.
(2) The requirements of paragraph (c)(1) of this section must be met:
(ii) In icing conditions with the final takeoff ice accretion defined in appendix C, if in the configuration of §25.121(b) with the takeoff ice accretion:
(d) Approach. In a configuration corresponding to the normal all-engines-operating procedure in which VSRfor this configuration does not exceed 110 percent of the VSRfor the related all-engines-operating landing configuration:
(1) The steady gradient of climb may not be less than 2.1 percent for two-engine airplanes, 2.4 percent for three-engine airplanes, and 2.7 percent for four-engine airplanes, with—
(i) The critical engine inoperative, the remaining engines at the go-around power or thrust setting;
(ii) The maximum landing weight;
(iii) A climb speed established in connection with normal landing procedures, but not exceeding 1.4 VSR; and
(iv) Landing gear retracted.
(2) The requirements of paragraph (d)(1) of this section must be met:
(ii) In icing conditions with the approach ice accretion defined in appendix C. The climb speed selected for non-icing conditions may be used if the climb speed for icing conditions, computed in accordance with paragraph (d)(1)(iii) of this section, does not exceed that for non-icing conditions by more than the greater of 3 knots CAS or 3 percent.
Whereas Boeing didn't find a requirement to use a snatch-back system for the thrust lever in the event of an unplanned thrust reverser deployment, an automatic stow system is in use and the need to demonstrate or certify climb with one in reverse was and is irrelevant. Boeing provides that one can either shut it down with the fuel control if it's a problem, or ignore it and fly, if it's not.
No assumption required.
§ 25.933 Reversing systems.
(a) For turbojet reversing systems—
(1) Each system intended for ground operation only must be designed so that during any reversal in flight the engine will produce no more than flight idle thrust. In addition, it must be shown by analysis or test, or both, that—
(i) Each operable reverser can be restored to the forward thrust position; and
(ii) The airplane is capable of continued safe flight and landing under any possible position of the thrust reverser.
(2) Each system intended for inflight use must be designed so that no unsafe condition will result during normal operation of the system, or from any failure (or reasonably likely combination of failures) of the reversing system, under any anticipated condition of operation of the airplane including ground operation. Failure of structural elements need not be considered if the probability of this kind of failure is extremely remote.
(3) Each system must have means to prevent the engine from producing more than idle thrust when the reversing system malfunctions, except that it may produce any greater forward thrust that is shown to allow directional control to be maintained, with aerodynamic means alone, under the most critical reversing condition expected in operation.
25.993 provides a requirement that either the reverser not affect the flight, or the flight be able to continue with the reverser deployed. The system must be designed such that if the reverser deploys, no more than idle thrust will be produced. The airplane was never required to have a system to auto-retard the thrust lever in the event of an unintended deployment.
Actually, no. You made statements in error, namely regarding a system to retard the throttle, and then made statements in error that Boeing certified the airplane to fly with one engine producing reverse thrust. Neither is true.
14 CFR 25.933 provides that:
a. If the system does reverse in flight, it can't produce more than idle thrust
b. a malfunctioning reverser has a means of restoring forward acting thrust
c. the airplane may be continued safely and landed under any possible position of the reverser. This does NOT imply that the engine must be producing thrust. This refers only to the physical position of the reverser...not to an engine producing reverse thrust, even idle reverse thrust. To meet this requirement, the engine may be shut down.
In your attention to minutia, as always, you miss the forest for the trees.
I said I *believed* the throttle would automatically retard to idle, but that I wasn't sure. Thanks for the clarification on that detail.
The POINT, however, was my certainty that the aircraft was perfectly flyable with one engine at reverse idle and the rest developing takeoff thrust. While your detailed analysis doesn't "imply" that an engine stuck in reverse is, in fact, still at idle, before it can be shut down, the simple FACT is that, in ANY aircraft with more than 2 engines, it takes a moment to identify which engine is faulty, confirm it, and shut it down.
I have flown aircraft with "auto-stow" features in the reverser logic and, the simple fact of the matter is, they don't always work. In a takeoff scenario where I had elected to continue the takeoff roll, I likely wouldn't be trying to figure out which one it was until AFTER breaking ground, the gear is up, and a positive rate of climb is established at target speed (some reverser deployed memory items on some aircraft are accomplished before minimum safe altitude, but always after the aircraft is at least climbing and stabilized in a climb attitude and airspeed).
So yes, you confirmed my assumption. No, nothing you've said before or after changes that basic assumption. Happy Independence Day.
My friend, who obviously was a very good pilot, had the right engine of a 727 go into reverse on take off in MIA. The engines remained at TO power on that engine while he was sorting out why the FO couldn't hold runway heading after takeoff. He assumed control to see why they were barely climbing and couldn't stay on runway heading with full rudder without using bank also. No indications in cockpit because only the outboard reverser of the engine failed in reverse. He found by bringing back the right engine to idle they could climb and return for landing. Boeing said they had never had it happen before. ******************** happens so don't totally rely on a checklist to get you back alive.
Great job guys! Way to keep cool under extreme pressure. You guys are a credit to the profession.
Great job BA!
As far as rejecting...a reject at over 120 knots in a 747 is a BIG deal. 14,000 feet is not a lot of runway if you are hot and/or high enough as it seems this airport was.
A high speed reject in a 747 is an EMERGENCY. Having a reverser unlock light illuminate without any other indication of a problem is an abnormal.
Even knowing everything I bet the Captain of this airplane would rather have to deal with some retracted slats on takeoff then reject at high speed.
A reject in a 747 and a CRJ are not even in the same league.
somebody's got check airman disease.
