I don't think its dishonest at all to put it in the fractional light jet category.
The Avanti has a cabin that is longer, wider, and taller than any light jet currently in fractional use; its cabin is actually taller and wider than all Citations including the Excel, Sovereign, and X.
The Avanti's cruise speed is faster than the Citation Bravo that CitationAir still uses, and the CJ1 Flight Options used to operate. Over a 600nm segment, Business & Commercial Aviation's Purchase Planning Handbook says the Avanti II arrives just 10 minutes later than a CJ3, but burns 27% less fuel. Or 13 minutes behind an Encore+, having burned 36% less fuel.
While I agree that there's a substantial delta between the Avanti II and "the top-performing light jets", when you look at the total picture I believe it quite accurate to put it in the Light Jet category...especially when comparing it to other fractional airframes.
http://www.urbandictionary.com/define.php?term=penis envy
Come on man, it's about what you get paid not what you fly. You guys really have nothing to be ashamed of, except for that overly cheerful co-pilot![]()
Perhaps the customers care. Does that matter to you? I think people know the difference between prop engines and jet engines.
Customers only care because they have been spoonfed a myth that jet aircraft are safer/faster/more comfortable/better than turboprop plane.
If they knew the advantages turboprops have over turbofan aircraft, they A. wouldnt care what pushes it, or B. would prefer a turboprop on shorter segments
Unfortunately most of what customers hear is the advantages of turbofan over turboprop instead of the other way around.
Unfortunately, many turboprop customers have been told that the speeds are the same and all other flight characteristics are the same such as climb performance, altitude capabilities, speeds at altitudes, ability to go above weather, etc when in fact, the turboprop has some significant limitations when compared to a decent jet.
I think it competes in both markets ... people looking at light jets and people looking at other turbo-props.Yes, we are a bit of a speed bump, but we compete in the same market as light jets, so the Piaggio gets compared with them.
Hey, they are turbines. Turbine = jet. Nuf said.
Just did PBI-BED today in 3+30 with the majority of the flight at FL390. Fuel burn was 2200lbs. Not too bad for a screw job.
Looking at flightaware there was a Citation 560 that did it in 3+10. Not too big a difference and I am sure our passengers enjoyed the cabin a lot more.
