Atlas jumpseat info
  • Thread starter Thread starter mar
  • Watchers Watchers 2
mar
Remember this one?
I tried to locate the exact memo or bulletin but haven't found it yet.
But 135 (air taxi) guys are finally approved to ride jumpseat on Atlas.
You need to submit a request at this url:
http://www.atlasair.com/travel/confirm.asp?type=1
Personal advice: have a back up plan and leave yourself lots of time. When flights are late they can be 24 hours (or more) late.
Good luck.
But wait. There's more.
I found the bulletin.
I should've mentioned, for the purposes of jumpseating, OAL (other air line) pilots are divided in two groups: CASS member and non-CASS but employed by an FAR 119 carrier.
If you're CASS approved, use the link above no later than 3 hours before departure, preferably more than 24 hours. Obviously CASS is only approved for domestic flights.
If your're a non-CASS pilot *or* an FAA licensed Dispatcher you must submit the request at least 24 hours in advance.
I'm a little vague on the passport requirement for non-CASS travel when it's either domestic or international.
I'd recommend carrying as many documents as possible to prove your identity.
All requests will receive confirmation of Flight # and Tail # via return email.
Emergency requests are taken at 914-701-8047.
Mar:
I'll have to print that out. It's been ten years since I was last in Dhaka--time to go back!
Much appreciated my man...
Dan
Dan, I'm worried about you
What business does a fine young man, such as yourself, have in Dhaka?
Maybe you own a sweatshop?
What are you up to these days? PM me if you like.
Ciao.
Careful
Flattery will get you everywhere.
Relax
It doesn't mean anything.
It's just a funny thing to say. A play on words. Irony.
Ok maybe it's not so funny.
I told you to never use my real name!!!
dispatcher121 said:
OK shoooogs question. What if you ARE an FAA Licensed Dispatcher that is CASS qualified?
(Note:Some of us CASS carriers ALSO have CASS approved Dispatchers! :D )
Well in that case sweet cheeks I'd say you're in like flynn!!!
Peace sister!
OK...So huh?
OK for the uninitiated, was is CASS and what is a CASS carrier? (and how do I know if I work for one?
Bugsmasher....
