ohplease!
- Nov 20, 2004
bailout said:>>yep. that'd be me.<<
Putz.......
peckerhead........
Putz.......
ohplease! said:peckerhead........
IFlyFL410 said:On an off note....has anyone been doing the 4.0 degree descent!?!?Tried it the other day according to the new revision. It states to fly at "idle" and adjust your descent rate to maintain a 4 degree glide path. Ok, so I do this and by the time we get from the upper 30's to the upper teens all of our airspeed has gone away. I wouldn't mind the 4 degree descent as long as we could adjust the power to be 10 below the barber pole.
Stifler's Mom said:IFlyFL410 said:On an off note....has anyone been doing the 4.0 degree descent!?!? quote]
Tried it the other day according to the new revision. It states to fly at "idle" and adjust your descent rate to maintain a 4 degree glide path. Ok, so I do this and by the time we get from the upper 30's to the lower 20's all of our airspeed has gone away. I wouldn't mind the 4 degree descent as long as we could adjust the power to be 10 below the barber pole.
Yeah, you really have to keep a touch of power in (500ish pph per side) to keep the airspeed up at barber pole-10. If they truely want us to fly power-idle descents, it would take more like a 5-6 deg. descent to keep the speed right at barber pole with idle thrust, and there's no way I'd feel comfortable doing that. I know I've done a 5 deg. descent before (not intentionally) and still had to bump some power in to keep the thing sped up.
One thing's for sure, as pathetic as this airplane is at climbing, it sure does descend well. Nice to know if you're ever left up high and need to get down.
GO AROUND said:Is this the 50 or 70 and How light were you? I don't think it was meant as an all the time procedure. All the 4 degree descents in the 50 I've done lately havn't reduced my airspeed at flight idle power, but they were 14, 16, or 18K changes in altitude. Of couse you can't pull the power to idle on all four degree descents and expect to hold your speed. A 3 or 4 thousand foot descent at 4 degrees is only 1500 to 1800 fpm.
