Corona
Upperclass Twit
- Oct 5, 2004
ATCER said:I don't work in a tower but I'll still try and provide some info. We have an order of priorities as to how we handle A/C ... unfortunatley what you were looking for is low on the list when things are busy. You are on the ground so in that order you do not need immediate attention, the attention is given to A/C already being worked in the system.
We also do not know what restricitions were placed on the tower... they may have had a temporary stop on IFR's not already filed... many times we are just told something quickly (eg. don't launch any for a few minutes) and have to wait to get the full story.
As for you not having ADF ... did that change your equipment suffix ?
OK, this thread had me digging into the 'ol AIM:
1) Sorry, ATCER, there isn't a suffix for ADF on an IFR plan (Yep; had to look that one up to verify what I thought I knew). However, the pilot is required to have the necessary equipment required to safely accomplish the flight IFR with the ground or GPS navigation aids defined by the flight plan. But, pilots are not required to have the published DPs (SIDs and ODPs). Hmm, this gets curiouser and curiouser...
2) Aim 5-2-6 goes into detail about what's required for DPs both from pilot and controller points of view. Ironically, the only requirement for DPs is that the pilot has text or graphic description of the procedure. Nowhere in the AIM that I have found does it discuss DP equipment requirements, except for RNAV DPs.
I think Immelman has thrown us quite a conundrum: Can ATC keep a pilot on the ground for not being able to comply with an ODP? Doesn't seem right to me, regardless of traffic volume. The AIM says ATC can issue ODPs as part of the clearance, but this seems an extreme interpretation to me.
Immelman, please do pursue this and let us know what you find. I suggest you start with calling the tower.
C
