Aspen Slope 2% ???
SabreFlyR said:
This is not true. I have a very good friend who on takeoff in a Citation 500 left most of the turbine section of one of the engines on the runway a few years back.
Before or after V1?
prpjt said:
This is a cut of a draft of AC 120-OBS-11. Looks like the fed's are trying to clear up this matter. I don't know if this has been relased as an AC. I highlighted some of the pertinent language.
TERPS CRITERIA VS. ENGINE-OUT REQUIREMENTS:
Standard Instrument Departures (SIDS) or departure procedures (DPs) based on U.S. Standards for Terminal Instrument Procedures (TERPS) or ICAO Pans-Ops are based on normal (all-engine) operations. Thus, engine-out obstacle clearance requirements and the all-engine TERPS requirements are independent. Engine-out procedures do not need to meet TERPS requirements. Further, compliance with TERPS climb gradient requirements do not necessarily assure that engine-out obstacle clearance requirements are met. Terminal instrument procedures typically use specified all-engine climb gradients to an altitude, rather than certified engine-out airplane performance. Terminal instrument procedures typically assume a climb gradient of 200 feet per nautical mile (nm) unless a greater gradient is specified. For the purposes of analyzing performance on procedures developed under TERPS or Pans-Ops, it is understood that any gradient requirement, specified or unspecified, will be treated as a plane which must not be penetrated from above until reaching the stated height, rather than as a gradient which must be exceeded at all points in the path. Operators must comply with FAR requirements for the development of takeoff performance data and procedures. There are differences between TERPS and engine-out criteria, including the lateral and vertical obstacle clearance requirements. An engine failure during takeoff is a non-normal condition, and therefore, takes precedence over noise abatement, air traffic, SID’s, DPs, and other normal operating considerations.
Prpjt...
Thank you. I was getting tired of typing.
The simpliest way I could probably state it is: The aircraft certification requirements will only get you to 1500' while clearing any obstacles. That's basically pattern altitude and if you've got a problem at that point you come back and land. Above 1500' and you're flying a DP and all gradients are based on "normal" (all engine) climb performance. If you can't make that then you have to have an "out". In our case, we had Jeppesen provide us with an "escape" or alternate procedure that we can fly that will keep our nose out of the dirt.
Don't feel bad if you misuderstood this. It's been misunderstood ever since Wilbur tried explaining it or Orvil, who coincidently, got it wrong. I know that I was taught wrong at FlightSafety and every other school for 20 years. It wasn't until a couple of years ago that I sat down with someone who really knew and understood it and was able to pound it into my thick skull.
A couple of months ago at our 6-month recurrent our FlightSafety instructor once again started to explain it wrong. We had an interesting discussion and he wasn't buying any of it. There happened to be, in our class, one of their part-time instructors who also happens to be a prominant aviation attorney and aviation magazine contributor. He was finally able to set the performance instructor straight.
If I was an FAA inspector and I wanted to wreak a little havoc with the Aspen pilot pool, I wouldn't worry too much about guys on take off. Where I would want to talk to them is right after landing. I would be most interested in knowing their landing weight verses their Approach Climb capabilitiy from the appropriate Approach Climb chart out of the flight manual. Watch out, it can be very restrictive.
Perhaps Kingairrick had it right when he said that perhaps this thread ought to be moved to the "Legal, but stupid" thread. However, it's important that we understand this stuff. You 121 guys have it easy - you've got folks to figure this stuff out for you. You 135 and us 01 guys have to fend for ourselves. In the past, how many of us have postponed or canceled flights that would otherwise have been completely legal? I know that I have. Airports like Aspen should be respected not feared. Like I said in an earlier post - it has to be very VFR before we either go into or fly out of Aspen. We're very fortunate, the boss has a ranch in Grand Junction and it's no big deal if we can't do ASE for whatever reason.
'Sled
LJ45 said:
Before or after V1?
After V1. Flew it around the pattern and landed.
The manufactures do not know everything that happens to their aircraft. The only way for them to know is if the operator tells them. In this particular case the engine was removed sent to the overhaul shop and reinstalled. Over the years I've heard some real bs from these guys.
Thanks for the info, I thought it sounded like propaganda!
A couple of things:
1) This is a really, really good thread. Especially for someone like me still down at the bottom working my way up. Even if the topic doesn't directly apply to me, I've learned an amazing amount regardless.
2) You guys are friggin' nerds! Especially you Lead Sled! :D
bigD said:
A couple of things:
Have you been talking to my wife?
'Sled
Oh man, if you only knew... Sled's like a celebrity at FSI.
I've sat next to him at recurrent. Any question the instructor can't answer gets thrown to 'Sled. He just sits there until called upon. I've yet to see him get stumped. The guy could build an Astra or Lear Jet out of old beer cans with a butter knife. I think I'd be better off just giving him 15 grand and sitting in his living room for an evening. Plus I'd get some of his wife's amazing cooking. That alone would be worth the $$$.:)
And yes, I was at his last performance class where this whole single-engine TERPS stuff came up... again. I think I saw the instructor burning the FSI syllabus after class.:eek:
Now don't get me started on his co-captain. Although the guy looks like Brad Pitt and flies like Bob Hoover, he's about as sharp as a water balloon.:D
Ah! Now it is all clear! HMR and Lead Sled...who would have thought....
With all of this talk of FS;..... Sled ? YOU wouldn't have the initials R.B. would you? Just wondering. Your take on this subjuct is very familiar.
And English, how's the 4 treating you? No hijack intended.
The 4 is great and fun. I'm down to only washing it once a week now ;)
Only once a week?!?! What kind of driver are you?! You need to have your BMW taken away and issued a Gremlin! :D
I know I know..I feel so unworthy!
Tell you what - since I'm such a nice guy, I'll take the car off of English's hands while she learns the error of her ways! :D
Sorry...after my husband crashed my beloved Celica, no men's hands will touch my new baby!
However...seeing as bigD DID just upgrade to a bigger aircraft, maybe I'll give him a chance.
Like to go fast bigD?
RB? No not me. I'm trying to figure out who it could be though.
'Sled
You're mistaken. My co-captain looks like Bob Hoover and flies like Brad Pitt. :p
'Sled
Visited the infamous ASE today for the first time. I have to say I'm disgusted at how this place is interpreted by pilots - we have so much conflicting info. on this airport and very little guidance from the Feds. I think this airport and others like it need an AC with specific instructions to stay out of the danger zone.
1. Holding short, Lear 30 Series decides to cancel IFR and depart VFR only to pick up their IFR after departure - huh? why? (they are not sure about the legality of things here, that's why)
2. Holdig short, G-III blasts off and tower says start the right turn. The pilots come back baffeled, "uh, can you give us that heading?" TOWER: "it's on the departure procedure sir, start the right turn." They obviously never even glanced at it before taking the runway. WTFO - another reason I'll never put my family on a chartered airplane.
3. It's our turn, my partner wants to depart VFR and pick up our IFR in the air (135 operation). Alright - I'm along for the ride. Nevermind we planned a TO 200+ lbs lighter at 6 degrees cooler. I knew the plane could do it - but this is sloppy to me. Not to mention that he had no idea what the departure procedure was until I walked him through it as we flew it. Poor. It's called a briefing and I have yet to see even a half-arsed one in this charter-land / 91 free-for-all land.
We need guidance on this airport. It's only a matter of time before another crew puts one in the dirt at ASE because of confusion on legality, performance, or procedures. We are being set up for failure. Heck - the story above of the FS guy teaching it wrong - if that doesn't say it, what does? Sure was pretty though, and the approach is FUN!
AZT
You think that was bad? Just wait until the ski season is in full swing and you're holding in position on 33 and there are two airplanes on final for 15. :D
The next time you fly in there make sure the guy sitting next to you reads the departure. The trick is to listen up and be predictable - the controllers are real good at what they do. Things can get all balled up when pilots don't pay attention. Blasting out of there VFR or cancelling your IFR approaching Red Table leaves everyone wondering just what you're going to do next. Operating out of Aspen can be a real challenge. A "professional" attitude and approach goes a long way there.
AZ Typed, don't take this wrong, but don't let the guy sitting next to you kill you - you'll live a lot longer that way.
'Sled
Lead Sled said:
You have an opinion from FAA Legal stating that you have to be able to make the climb gradients listed in a departure procedure (TERPs) with an engine out?
This is an excerpt from the 8400.10, FAA Inspectors Handbook, Volume 4, Ch 3:
"(2) The criteria for TERPS does not take into account whether or not the aircraft is operating on all engines. Operators must either show compliance with TERPS criteria with an engine out or have an alternate routing available for use in case of an engine failure…."
So how do you do this in a caravan or a PC12?
As Prpjt posted a few days ago, there is a draft Advisory Circular (AC 120-OBS-11) that pertains. I've cut and pasted it from his post:
You guys who haven't done should get a hold of the folks at Jeppesen Ops Data. The cost is pretty reasonable - something like $22 per runway per configuration (ie flap setting, etc). The procedure that you will receive is not “one size fits all” – it is airplane specific and even specifies the bank angle. The procedure for our airplane even varies according V2. It’s a complicated emergency maneuver but it will allow you to take the airplane to a safe place in mountainous terrain.
As far as how to best employ it? It depends upon your particular set up. We have it loaded and waiting on FMS #2. If there's a problem we simply have to select it as the nav source for the guy in the left seat. The transition from the DP to the escape maneuver is direct and seamless. During a normal departure we simply cross-fill the flight plan data from #1 back to #2 after we’re out of the terminal area and drive on. You need to carefully brief the various actions in the event of an engine failure. The co-pilot’s going to be pretty busy and both guys need to make sure that the navigation is being sourced from the proper FMS once you turn off of the Lindz 4. Remember, at that point it’s an “honest to gosh” emergency and no one’s going to question your actions as you turn out and fly Jeppesen’s alternate procedure – that’s what you’ve got it for. It sure beats sticking your nose in the dirt.
'Sled
Wow
Lead Sled:
When we (regional airline) started to fly to the mountains of Mexico, Colorado, Utah and Nevada (not with standing DPs out of ROA) we got specific training for and charts for escape manuvers if we had a engine failure at or shortly after V1.
Wish we had dual FMSs to do what you discribed but alas we didn't and it was very busy during Ck rides for the non flying pilot.
Don't know where we got the charts (I suspect Jepessen) but they were very specific as to bank, turns and procedures.
As someone who is looking for 91/135 work I'll be interested in operations that use all available resourses to make mountain flying as safe as possible.
CarjCapt
From the draft AC
I still stand by the requirement to either meet the climb gradients with an engine inop, have an escape procedure, or be able to see and avoid the obstacles.
So help a FNG 135 fella out and put it in practical language:
1. can you depart IFR in VMC without getting nailed by the Feds if you cannot meet the climb gradient (I think the answer is no based on this post)
2. under 135 you must meet the climb gradient under all conditions (I think the answer is yes, again based on this discussion)
3. if you cannot meet the climb gradient, no matter what the wx, you must lighten the fuel load (to meet the gradient) and get gas somewhere, correct? (I think the answer is yes)
4. the whole second segment climb gradient as a % is new to me. I have always been taught the get a rate of climb out of the aircraft based on groundspeed. In the 121 world it was done for us. Now in the 135 world I'm tossed into the % concept. How do you determine the % second segment climb for the airport? Rise over Run? Can you give an example at say, ASE? FS did a terrible job covering this and I knew one day I'd be heading to ASE.
Thanks for the help!
AZT
So,
can anyone answer these questions? Im headed there this week and would like to do this right.
johnny taliban said:
So,
1. yes
2. no
3. no
4. required percentage is required rate (in feet per mile) divided by 6080.
The Legacy is +2% / - 2% FWIW.
Now, to show my ignorance... What is a single engine climb gradient based upon when certified? Is it based upon reaching acceleration altitude at V2, then accelerating or is it based on something else? (I believe it is the standard acceleration alt to VFS thing, but now you have me confused.)
Our approved engine-out procedure now is to hold V2 until a safe altitude is reached, period. It seems to me it makew our effective single-engine climb gradient STEEPER than the standard method. With all the power available in modern jets, acceleration segments seem a bit outdated. Am I wrong?
Again, sorry to sound like an ignoramous, but I am trying to phrase this as best I can...
I am also effectively a Part 135 noob, but will address this as I understand it (and now believe is wrong):
Yes you can depart and not meet the 3.3 degree single-engine gradient requirement under 135 if you have a visual escape plan (or an approved escape procedure for the airport).
No. Only under Part 135 in IMC conditions at an airport without an approved instrument escape procedure. Under VFR a visual escape allows you to sidestep the 3.3% requirement.
You must only meet the gradient under IFR when a certified IFR escape procedure does not exist.
We determine it from (I BELIEVE) 35 feet above the end of the runway to safe altitude at V2.
Also, correct me if I am wrong, but aren't we required to meet the 3.3% gradient at all times (unless a steeper gradient is required), even Part 91, unless we have a visual or charted escape path? This is all based upon NET CLIMB GRADIENT data...
