ASA, Comair, Delta non-revs on Skywest
  • Thread starter Thread starter Willy21
  • Watchers Watchers 11
Willy21
Don't ask
My family and I just got back from the west coast trying to non-rev on Skywest. I am an ASA pilot and I ran into a interesting situation. On two flights out of a Skywest city we got bumped by a Skywest buddy pass, listed as a S4 on travelnet (to get home I spent $800 on Eagle and $180 for a hotel). I had a jumpseat pass filled out and was willing to do that to get to SLC. I understand that on Skywest flights active ASA, Comair, and Delta people only get a S3C priority. Likewise on Delta, ASA, and Comair flights Skywest people get S3B priority. They still get on ahead of our buddy pass riders. So my question is was the buddy pass getting on the flight ahead of me propper procedure? If it is then why is that not true on Delta, ASA, and Comair flights with actively employed Skywest non-revs?
Second, when does the non-rev list close on Skywest flights? On the second flight the last non-rev, also a buddy pass rider walked up 5 mins after scheduled departure and was boarded. They held the flight for him even though my wife, daughter and I were in the gate house ready to go.
Also when I non-rev on a Delta flight (DL, EV, ect.) I have to conform to the Dress code that Delta has published. One of the buddy pass riders was wearing shorts. I asked the agent at the gate about it and she said that was propper attire for a Skywest non-rev. I then asked if it would be alright for my family to put on shorts and she said we would be denied boarding. Why the difference?
I understand that non-reving on the west coat or anywhere can be difficult at best. I would like to think that when I am in the right seat spinning the wheel I will make it happen for any non-rev or jumpseater if I can. That is just a good practice because you never know when you might need the help. It just sucks when you think you got the shaft. Skywest pilots, If I did get the shaft who do I call so this doesn't happen again.
Contact your pass bureau as they will have the answer.
Skywest might allow their internal buddy pass riders priority over offline carrier travel pass holders. Maybe the buddy pass rider was a family member of the gate agent and you got hosed... Either way, contact your company and check with them.
If something was done incorrectly, you should file a complaint and have Delta investigate. You won't get your money back, but you might get a gate agent fired and or disciplined, which might send a message to other gate agents to follow the rules.
Post a reply when you find out the real deal..
Getting somebody fired is not my goal, just want to know if what happened is what should have happened. I also wanted to let Delta, ASA, and Comair pilots know that if this is the correct procedure they need to look at the buddy pass riders a little closer.
I non-rev on ASA a bit and allways get S3C with SKYW ID and SKYW gate agents? I am usually the last non-rev on the list.
Here is some cut and paste info I found regarding NRSA with connection carriers.
Dress Code Guidelines
Dress code guidelines vary among carriers. Always check with the operating carrier before traveling.
Family & Friends guests are eligible for travel on SkyWest on any flight operated on behalf of Delta.
The boarding priority for Family & Friends guests is SA4.
Nonrevenue travel on SkyWest flights will follow the same non-rev travel procedures and guidelines as a Delta flight with the exception of the boarding priority. The boarding priority is S3C or S3CR.
Sorry for the sloppy post, but it is mostly cut and pasted info from dalweb.
You are still boarded above the buddy pass (S4). I was listed as a S3C, no problem, it was a Skywest airplane. The thing that gets me is a non-employee (buddy pass) was cleared before an active employee.
Just a shot in the dark here, because I know it's apples and oranges, but maybe the buddy pass riders were travelling with the employee? If I recall correctly, at UAL buddy pass riders travelling WITH the employee get the full benefit of the employee's seniority AND their boarding priority (but I could be totally wrong). If they're alone, then they're bottom of the barrell.
He was the only non-rev that got on the flight. I was trying to get my wife on the flight so that I could take the jumpseat.
SKYW Buddy pass riders are S3C2 on SKYW flights last time I checked,
We dont have Buddy passes on mainline or other carriers. I never really understand what goes on behind the counter half the time, its like trying to get info out of Fort Knox. I usually just shake my head and walk over to LUV!
Really. This is news to me. (I don't nonrev on Skywest too often). Sort of bullcrap if you ask me. I think (but I'm not 100% certain) that Delta pays Skywest on an ASM buy (cost-plus) type schedule. That means Delta essentially charters the Skywest aircraft to fly where we want to them to fly. Which means DL is basically chartering the whole aircraft, and as such DL is buying all 50 seats on an OO aircraft every time. By extension, all 50 of those seats technically belong to Delta, not Skywest. Very interesting. You'd think Skywest would wise up and see that from a nonrev POV they have more to gain from DL than DL has to gain from them.
Trip
Is a S3C2 a higher priority than what a ASA employee would be on? If you could find out it would help me out.
Trip is right on both counts:
1. SkyWest buddy passes are S3C2.
2. SkyWest buddy passes are for SkyWest only. They don't count for mainline Delta (or UAL) flights, which obviously can be a severe handicap for anyone trying to travel on a SkyWest buddy pass.
I don't know how the buddy passes work at ASA, but assuming they work on mainline and other DAL Connection carriers, that's a huge advantage over SkyWest buddy passes. If there is in fact a higher priority on SkyWest for SkyWest buddy passes (I don't know that there is) that might be a logical explanation.
By the way, as far as the crews go at SkyWest, I've never seen a single person who doesn't go above and beyond to accomodate non-revs and jumpseaters (as long as we're informed of them of course), regardless of what airline the non-revs are from. That's also been true when I've JS'd on ASA. The crews are totally accomodating and professional, and it's greatly appreciated. I assume that's the case at all regionals. You'd have to be a pretty big a-hole to discriminate against a fellow crewmember or their family based on what airline they happen to work for.
Big L
In no way should an employee be bumped for a buddy pass (any buddy pass). If this happened to me, I would contact the pass bureau and maybe even send an email to the station manager asking for an explanation. They should take this seriously. Pass benefits are one of the last benefits that have remained largely untouched, and it's a shame to see people get hosed like this. I'm going along with the buddy pass being a friend/family member of the gate agent theory.
