  • Logbook Pro for Apple iOS version 8.1 is now available on the App Store. Major update including signature endorsements and dark/light theme support. Click here to install now.
Any tips for a Cessna 421B Pre-BUY
Jetdriver125
Member
Total Time
2550
I am wanted to see if anyone has and tips on what to look for during a Pre-buy Inspections Any secrets or hiddens i might want to know about???
deadstick
Pucker Factor: HIGH
Total Time
e^x
If it has the GTSIO engines, run. :)
Seriously, I'd ONLY look at one that is the right price with run-outs. Do the core exchange for factory reman/new engines and treat them right. I knew a guy who bought one with 100 hrs on 2 blue printed engines. He knew his stuff, and within the first 200 hrs, all 12 jugs were replaced.
I hear the Centurion 4.0 is heading for a 400-series STC. In the Duke, they are burning 24-25 gph. Not bad at all.
Really watch for the cracking issue, too.
rotor&wing
Total Time
+1
Essentially do a 100 hour inspection as per the C421 MM. Do a comprehensive AD search. The exhaust section/turbo requires a very close and detailed inspection as well as the bed mounts for the engines.
Say Again Over
With you
Total Time
13K
No hidden secret, but to add to the above post, check the pressurization, make sure the system is up to spec on a test flight, and go for non engine driven freon air conditioner.
jetpig32
Total Time
dimsum
AD's - Continuous
Starter Adapter
Exhaust
Fuel Inlet Valves
Upper Spar Cap
Heater Fuel Valve
Heater Itself (if old model Kelly Aero/Janitrol)
