LAXSaabdude
- Jul 25, 2002
I believe that the FAA prohibits the use of any ethanol in any aircraft engines that are certified to run on mogas (i.e. Continental/Lycoming).
Now here's a question. If one was to build a VW powered experimental aircraft, could you run it on a gasoline/ethanol mix? Assuming, of course, you took care of all of the physical details - rubber seals, anything that may deteriorate with ethanol.
Just how much latitude does the "Experimental" designation get you as far as fuel goes?
Thanks.
LAXSaabdude.
Thanks.
LAXSaabdude.
