ALPA FT/DT Recommendations - WRITE ALPA NOW!
WolfManPack
Please join me in opposing the proposal from ALPA on the Flight Time / Duty Time proposal. Write ALPA at [email protected]
See my e-mail to them below:
To Whom It May Concern:
I find it incredible that ALPA, an association that is supposed to represent the
interests of its members and keep their safety in mind at all times, has proposed increasing
the amount of flight time from 8 hours to 9 hours.
This is yet another example of how out of touch the Association is with its membership.
First it was the Age 60 rule change and now this. In an effort to reduce pilot fatigue,
ALPA has proposed flying longer hours in the air without supplemental crew.
With a supplemental crew, anything above 7 hours gets my support but increasing the
amount of flight time without supplemental crew is simply unacceptable.
Again the membership was ignored in a career changing process. No polls were taken no
feedback garnered other than hand-picked representatives that are known to have advocated
contract concessions, etc.
When will my union begin to stand up for safety instead of its own, selfish motives?
Concerned,
Brad Day
ALPA # 243699
I don't get pilots.
Some were complaining that the new FTDT rules would lead to more days of work and less days at home. Now we're up in arms that we're being asked to work one more hour of block, only during a period of 6 hours when the human body is at its most alert state, and we're complaining?
These FTDT rules weren't pulled out of somebody's rear end. They're based on all the heaps of fatigue research over the last 50 years. We all knew that we would win some and lose some, because you can't cherry-pick what research you want to follow and be credible at the same time.
Have you looked at the industry's proposal at all? It's linked in the ALPA email. If you really want to see the screwjob that could happen, read that. How about flying for 12.5 hours of duty, with no set flight time limit, and then having a 10 hour overnight reduced to 9? That's what you should be lobbying against.
I understand there are some like you, that believe productivity should trump any concern with safety and fatigue. But, just to let you know, most pilots would rather be safe than productive.
I've flown the trans-cons. I've flown 8 hours a day with multiple legs a day. I know that flying 8 hours in one day without suplemental crew is NOT safe. You know if you had to do that just once a week, it might be different. But you don't just fly one, 9 hour day a week.
Again, let me reiterate, if they want to fly us up to 9 or 10 hour a day WITH suplemental crew, then by all means let's explore that. But just two pilots flying any more than 6 or 7 hour a day is NOT safe. I don't care what you say!
For those of you interested in protecting safety in aviation and stopping the continued downward spiral of our profession, write ALPA, write you congressmen and do it now.
I don't get pilots.
Wolfpack reminds me of the tea beggars or as they like to be called TEA party members. Afraid of change and seeing any new ideas and reasons only in the form of absolutes.
If the FAA increases the max flt hours to 9 and reduces the max duty from 16 hrs to maybe 14 or even 12.5 I dont see any relief on fatigue. Most airlines have a max duty day to be scheduled around 13 or 14 hrs MAX any way with the contract so you will still get shecduled 12hr and 59 min duty days with and extra leg or 8.5 or 9 hours of flying vs 8hrs.
I think ALPA's proposal is excellent. Flying up to 9 hours of duty, only during peak circadian rhythm, and limiting the duty day, is a wonderful solution. It increases allowable productivity (pay) while not sacrificing safety in the slightest. In fact, it increases safety because the duty day is reduced and the 16-hour Whitlow limit is replaced with a stricter standard. Good all around.
I swear, some pilots will find a way to bitch about anything.
Wolf, I think if you look at the proposal as a whole it is much more restrictive and based on science. With the exception of allowing 9 hours of flight time for pilots who report from 0700-1259, this is more restrictive.
For those of us that work at legacies and majors, you are probably correct. This is directed at the regionals who regularly schedule their pilots to 13 or 14 out of the box...then with delays get to 16.
I have no problem with going to 9 hrs of flying if duty period is reduced as proposed, it isn't the flying that makes me tired, it is the 2-3 hours breaks in the middle that does, in addition, I think if allowances are made with respect to number of landings, that will to add to less fattigue and it will prevent the commuters from running their pilot to hard.
I'm pretty sure you wouldn't say that to a "Tea Baggers" face would you. If so give me a call so we can meet somewhere you ***********************************!
Have you ever known ALPA National to get anything in return without giving away the whole farm first?
Hi!
I hope they make some reserve rules.
It sucks to do 250 hours of consecutive reserve duty, and then be called at 0200 for a 16+ duty day!
cliff
NBO
And, two 5 hour transcon legs, in a 12 hour duty day, is MUCH less tiring than doing 7+45, with 7 legs in a 16+ hour duty day.
