Crossky
A Gentleman and a bother
- Sep 23, 2004
Adding the FF's at cruise nails the airspeed issue..e.g 280 kts, 1400 lbs/side.
Take your landing weight speed card drop the last 3 zeros and add 20, that will be an approx N1 setting (47000 ---> 47 + 20 to get 67% N1 fully configired at the marker.
Going to pitch mode before adding flaps or pulling one notch of spoilers helps that pitch ballooning from the flaps deploying
Disconnnecting the a/p by using the trim makes the disconnect sometimes smoother
We're taught to set 80-85% N2 configured on approach. N2 because below 79.1% N1 the engine speed control syncs N2, not N1.
Even in pitch mode the autotrim will occur when selecting flaps, won't it? Selecting flaps below 200 and/or hand flying with flaps extention above 200 is better.
Disconnecting the A/P using the pitch trim switch disconnects both yaw dampers as well. Do you really want to do that? The A/P disconnect bar on the flight guidance panel is nice, try it.
