-[FONT="] [/FONT]5.L-6-2 – If a pilot is improperly awarded a line and submits a valid protest, the company must re-run the bid. HOWEVER, the current language requiring the company to make the pilot “financially whole”, i.e. be paid for the line he SHOULD have been awarded and days off, duty and TAFB (per diem) has been REMOVED and does not exist.
-[FONT="] [/FONT]5.M.1.a.3 – Carry-In day conflicts will be resolved in terms of highest carry-in groupings and seniority, i.e. 3-day carry-ins fixed from most senior to most junior pilot, then 2 day carry-ins, then 1-day carry-ins. This actually skews seniority to a certain extent.
-[FONT="] [/FONT]5.M.1.a.4 – Any FAR conflict adjustment will be done on the front or back end of the pairing in the NEW bid period and will be kept to the minimum required. In other words, if you need a 24/7 day off, they can take the first or last day of the pairing in the NEW month to adjust, but won’t take the pairing out of the previous month and adjust it. This could result in a single day off, but is about as good a fix as it gets and is consistent with what they already do now.
-[FONT="] [/FONT]5.N – SAP
[FONT="]o[FONT="] [/FONT][/FONT]Addition of reserve coverage checks for SAP 1. Currently we have no minimum coverage and they don’t check coverage for SAP 1. Now they want to add it.
[FONT="]o[FONT="] [/FONT][/FONT]The “floors” are much too high, starting at 22% required reserve coverage, up to 31% on weekends, and 40% on Holidays and weekends that are considered part of the holiday, such as Memorial Day Weekend.
[FONT="]o[FONT="] [/FONT][/FONT]Reserve coverage checks the same for SAP 2 as well, MUCH too high.
[FONT="]o[FONT="] [/FONT][/FONT]No “trial period” to see if this coverage level will work and will allow the system to work as good or better than the current system.
-[FONT="] [/FONT]5.O.1 – A pilot is required to clear all pending notifications 24 hours prior to the beginning of the next bid period’s operation (usually by the end of the day on the 28th). If the pilot hasn’t cleared the notification for a trip within 10 hours of the report time, he may be removed from the trip without pay.
[FONT="]o[FONT="] [/FONT][/FONT]Note: No allowance given for pilots on trips during this time who don’t have access to a computer.
-[FONT="] [/FONT]5.O.4 – If a pilot knows he is going to be out sick for more than 3 days, he must let Crew Scheduling know the planned duration of the sick event.
-[FONT="] [/FONT]5.O.5 – Return to original trip after calling out sick:
[FONT="]o[FONT="] [/FONT][/FONT]If a pilot calls out sick and wants to be put back on the trip later, he can’t do it sooner than 12 hours from the original report time of the trip.
[FONT="]o[FONT="] [/FONT][/FONT]If any portion of his original flight assignment is “
available”, Crew Sched
MAY return the pilot to that flight assignment. No mention of what “available” means and no guarantee they have to agree with you or put you back on the trip.
[FONT="]o[FONT="] [/FONT][/FONT]If it’s not available and another assignment comes available, you can pick that trip up (current system).
[FONT="]o[FONT="] [/FONT][/FONT]If neither of those options is available, you can
“request” that Crew Sched place you on reserve and you’ll get paid whatever reserve period pays (3.5 hours per day IF you fly, nothing if you don’t).
[FONT="]o[FONT="] [/FONT][/FONT]If they don’t use you per the above, they take it out of your sick bank, even if you sat reserve.
[FONT="]o[FONT="] [/FONT][/FONT]If you rejoin your trip, you don’t get the minimum daily average for the day you rejoin the trip, just leg by leg credit for what you fly.
-[FONT="] [/FONT]5.O.6 – Late Report
[FONT="]o[FONT="] [/FONT][/FONT]If you can’t report on-time, you have to tell Crew Scheduling not only the time you will be there, but also why you’re late and it will be recorded.
[FONT="]o[FONT="] [/FONT][/FONT]Your pay will be reduced for the trip(s) you are removed from.
[FONT="]o[FONT="] [/FONT][/FONT]Crew Scheduling decides whether they want to delay the flight, put you back on it later in the day, deadhead you out to rejoin it, reassign you to whatever THEY want, if it will return you to domicile no later than the end of the last calendar day of the original flight assignment, or offer you reserve.
[FONT="]o[FONT="] [/FONT][/FONT]It’s not clear if you’d get paid for taking reserve in this case, 4.V.7.c simply says you’ll get paid the credit of that assignment which, in this contract, is ZERO if you don’t fly on reserve.
-[FONT="] [/FONT]5.O.9.a.2 – No compensatory day off for a return to domicile past 0200 on your scheduled day off.
[FONT="]o[FONT="] [/FONT][/FONT]If the delay does NOT result in an additional duty period to get back to domicile, you do get paid the duty-period guarantee for that day, which is 4.5 hours.
[FONT="]o[FONT="] [/FONT][/FONT]If the delay DOES result in an additional duty period to get back to domicile, and you get back before 1000, and you only have one day off, you get no compensatory day off and you will be paid 1.5 * the block for that day OR 4.5 hours, whichever is greater.
[FONT="]o[FONT="] [/FONT][/FONT]If the delay DOES result in an additional duty period to get back to domicile and you get back AFTER 1000, they check to see if you are scheduled for more than one day off now. If you are NOT, and only have one day of now, you will be given an additional day off (doesn’t say when or where), and be paid the greater of 1.5 * the block for that day OR 4.5 hours, whichever is greater.
-[FONT="] [/FONT]5.O.10 – If a flight cancels, the pilot must immediately call Crew Scheduling. They have 30 minutes to either:
[FONT="]o[FONT="] [/FONT][/FONT]Keep the pilot on the original trip, except for the cancelled leg(s),
[FONT="]o[FONT="] [/FONT][/FONT]Reassign the pilot, or
[FONT="]o[FONT="] [/FONT][/FONT]Release the pilot until his next assignment.
-[FONT="] [/FONT]5.P.1.c – Reserve pilots can now mix CDO assignments with RS2 and go back on late reserve instead of being required to complete another CDO or be released for 3 days (current book). Dangerous fatigue-related concession.
-[FONT="] [/FONT]5.P.1.f – A Reserve pilot may be assigned to a trip that originates OUTSIDE his Reserve Period (TAP).
-[FONT="] [/FONT]Gave up the requirement to be released from reserve at least 12 hours prior to the report time of the next day’s trip.
-[FONT="] [/FONT]Gave up the requirement to be released immediately following a trip if the NEXT day’s trip report time was less than 12 hours away.
-[FONT="] [/FONT]Gave up the 30 minute availability period after a flight assignment for reserves and extended it to 6 HOURS.
-[FONT="] [/FONT]Gave up the prohibition to assign ready reserve AFTER a flight assignment to a Reserve pilot.
The NPA is saying that a pilot who gets Ready Reserve after a flight assignment will get 4 hours additional pay, but that’s not how Section 4 could be interpreted. 4.U.2.a says “A pilot who is assigned Ready Reserve (RR) and does not receive a flight assignment will receive a minimum duty period guarantee of four (4) hours. In this case, the pilot already WAS given a flight assignment, and will now only get what the flight assignment paid or 4 hours, whichever is more.
-[FONT="] [/FONT]Gave up the limitation that “No reserve pilot will be required to fly more than 2 hours past his last TAP prior to a scheduled calendar day off”. Now extendable into your day off.
Tactical Reserves
-[FONT="] [/FONT]5.P.3 – 12 hours notification to report to domicile for duty. This call could come at 0200 in the morning and you’d have to be there by noon.
-[FONT="] [/FONT]5.P.3.a.2 – Following a day off, a TR pilot will not be required to report to domicile or be reassigned RS1 or RS2 prior to a 1000 report / TAP.
-[FONT="] [/FONT]5.P.3.a.3 – Such reassignment, including assignment to a trip or RR, wil be made by 2000 on the day prior to the first day of a TR block of TAP of duty days. After that, such assignments will only require 12 hours notice.
-[FONT="] [/FONT]5.P.3.a.4 – The pilot will be responsible for verifying his schedule and clearing all notifications for the FIRST day of TR by 2000 on the previous DAY OFF.
[FONT="]o[FONT="] [/FONT][/FONT]Note: This means that they want you to be contactable by 2000 on your off day prior to your first day of a TR block of days in order to be notified of changes.
-[FONT="] [/FONT]The TR pilots can have their days off moved just like other reserves.
-[FONT="] [/FONT]5.P.4.h – A Reserve pilot may be assigned to a Ready Reserve duty outside his domicile.
[FONT="]o[FONT="] [/FONT][/FONT]Such assignment may not exceed 3 calendar days.
[FONT="]o[FONT="] [/FONT][/FONT]Deadheading to/from the outstation sit is paid in addition to Ready Reserve pay.
[FONT="]o[FONT="] [/FONT][/FONT]The six hour RR period starts when the reserve pilot ARRIVES AT THE ASSIGNED OUTSTATION AIRPORT.
