A330Driver
Active member
- May 10, 2005
That is a true statement. There is no way for Captains to pickup FO trips in FLICA.no, they can't pick up open FO time, they have to be asked by scheduling or the real dipsh#ts call scheduling!
Yes. They can and there are a few that do it. Then there are others that scheduling has tricked into doing it. They have done things like look to see who is non reving on a flight. Then call and ask if you will fly your leg home..... as f/o... because the flight will be canceled and you dont. Once they get some ass to say yes, they reassign the f/o that was already assigned that flight. The airtran philosophy is that your on reserve once you check in for a trip. So they take the original f/os trip away. This is a really crappy place to work.
I'm sure it's because the brown ones are ugly and can't be worn anywhere else except work for the most part... who wears a brown bomber jacket??So do some pilots wear black ones to be bold?
