Can anyone tell me how hard it is to get a florida base out of training. I have 135 min and a little bit more. Thinking about changing careers and was looking at Airnet and some other cargo operators.
If you have 135 mins you can choose your base. You will work 8 on 6 off until a run in the base you chose comes open. There are is a prop run in Tampa, and one in Ft. Lauderdale.
Choosing your base is at best a little missleading! This something you would have work out before coming to class and you better get it in writing before attending. You are not going to be able to come in and displace someone from their base/run.
The recruiter I talked to said, that it isn't done that often and some folks have been turned away because they were not able to relocate.
As far as Tampa and Ft. Lauderdale, I was told by our disatchers that it was closed down. It wouldn't be the first time they were wrong!
