Gatorman
Snot-nosed college boy!!
- Jul 24, 2003
If a soap solution is sprayed onto each potential leak site, bubbles will form where the gas leaks. What type of soloution depends on the gas. In this case, oxygen. You can't use any soloution with a petroleum base, because it reacts with with the oxygen. While some mechanics will use a dishsoap solution, a special solution is sold just for use with oxygen systems which doesn't leave a deposit, doesn't attract dirt or contaminants, and doesn't react with oxygen.
Wow, I sould start visiting the site again more often.
It appears that his question is what to do with the bottle if it is found to have no pressure in it. Of course he will locate and repair the leak. BTW it is not recommended to use 'dish soap', the product used for detecting oxygen leaks is call SHERLOCK ( http://wintonproducts.com/id21.htm )
Anyway, back to the subject matter - I have always taken the safety route, so when it doubt sent it out and have it inspected. I was going to just leave it at that, but I knew that if I did some one would bust me on it.
So, here is what Uncle Fed sez :
Do not attempt to charge oxygen cylinders if any of the following
discrepancies exist:
1. Contaminated fittings on the manifold, cylinder, or outside filler valve.
If in doubt, wipe with stabilized trichloroethylene; however, do not permit
solvent to enter any internal parts. Let air dry.
2. Cylinder out of hydrostatic test date. DOT regulations require ICC or
DOT 3AA designation cylinders to be hydrostatic tested to 5/3 their
working pressure, every 5 years. Cylinders bearing designation ICC or
DOT 3HT must be hydrostatic tested to 5/3 their working pressure every 3
years, and retired from service 15 years or 4,380 filling cycles after date of
manufacture, whichever occurs first.
3. Cylinder is completely empty. Do not charge, as the cylinder must be
removed, inspected, and cleaneddiscrepancies exist:
Here is the link where I found it:
http://www.tc.faa.gov/logistics/grants/pdf/1997/97-g-005.pdf
