moxiepilot
Florida Pimp
- Apr 13, 2005
I need your help in remembering the title of a book on aircraft engines which I believe focused on turbine engines. The book basically had silouetttes of all different types of engines, P&W, Rolls etc which showed the stages of compression and flow.
It also listed the aircraft engine model code and explinations of what the code means. For example, LIO-360-A3B6D is a left hand rotation crankshaft, fuel injected, opposed cylinders, 360 cu. in. displacement, with counterweight application in the accessoory section. Or PT6-A-20 is the 6th model of P&W blah blah blah...
Has anyone read or remember the name of this book?
Thanks a bundle - it's driving me crazy
