Air Ambulance BE20 (KLNK)
Not open for further replies.
jergar999
The hospital I work for is currently negotiating with a broker who has a buyer for the BE10 we are currently flying and a BE20 already configured for air ambulance as part of the deal. The aircraft they are looking at is a 1980 200, and rumor is it is currently in LNK. I'm assuming the aircraft is owned by a Lincoln based charter company whose name I shall not mention.
Basically, I'm wondering if any of the multiple posters who have worked there know any specifics about this airplane (particularly maintenance) that a prospective buyer might want to know.
Thanks in advance for any replies.
To Jergar999
The aircraft you are referring to is N280SC,a BE-200,when it came on certificate at LNK, at the FBO's charter dept. that shall remain nameless,in July 2001,it supposedly had between 4k and 5k hrs.total airframe, and had fresh overhauls. It cannot have flown much more than 1k hrs since then.Check with the operator at LNK.
Goodluck!!!!!
G-force
Air Ambulance Operator (LNK)
Sorry to say, both of those aircraft are in really bad condition.When they were purchased the aircraft were in good condition and unfortunitly the current operator does not keep them in very good shape. I know the King-Air 200 was hot started numerious times and the King-Air 100 is a pile of junk with 13,000 hours.This is a real good case of buyer beware!
To jergar999
By all means,if your firm is considering a purchase,do a very thorough PRE-BUY INSPECTION and also a very thorough RECORDS CHECK on the aircraft in question,at a maintenance shop that is REPUTABLE.
Best of Luck!!!!!
How does one "hot start" a king air numerous times? It's hard enough to hot it once, let alone repeatedly.
Are the batteries completely dead, along with the pilots flying it?
1981 was the first year for the B200, so this 1980 aircraft should be a straight 200 with the -41 engines. You'll have some temp-limiting problems when flying in and out of hot & high strips.
Ditto on the pre-buy inspection, but of course this applies to any aircraft purchase that exercises the proper due diligence.
Hope all goes well, enjoy your King Air. They really dress up any ramp that has a lot of jet trash parked there.
I can't recall ever having any temp issues in a BE20 with -41 engines, or with -42 engines. Even operating exclusively out of hot, high density altitude mountain fields. It has to be a pilot thing.
Hot Starts On King-Air 200
This was a common problem on this King-Air 200.It was caused by pilot neglect and an abundance of new hires,with little or no training.The FBO where the aircraft are based, had very bad maintenance practices.
Thanks for all the replies. The aircraft is advertised as having both engines timed out, so both would go to Dallas Airmotive or the like before delivery. The hot start thing made some bells go off for me too. As long as battery voltage is there, I have never seen our -28's even come close to the operating limit, much less the start line. Being Canadian must mean cooler starts. The Garretts (TPE-331-5's) are a much different story though.
Even if the battery condition is low, there is no excuse for a hot start. If the battery won't spin up enough to get the engine through a stable start in one shot, the fuel may be cut off briefly and then restored. This drops the termperature without any notable RPM droop, the engine begins to accelerate again from a lower temperature, and two or three cutoffs ("blips") results in the engine coming on speed on-temperature without hot starting.
If the engine is hot starting, it's pilot error.
The -45R runs like that, and pilot modulation of the fuel to control temperature is SOP. It's not uncommon on other types of turbine engines, either. Certain of the Allison C250, and various pratts sometimes require the same thing. Especially when starting on the battery. The bottom line is that the most basic duty of the pilot during the start is to monitor, and use the cutoff function of the engine control to prevent an overtemp. If the engine is overtemping, somebody needs their butt kicked...and quite possibly fired.
It could be that there was an overtemp in another phase of flight that people just blamed on a hot start.
Avbug, are you saying you should be jockeying the condition levers around if you can't get the starter to spool up enough?
Some engines tend to start hot and slow. The -45R I mentioned is one of them. Pilot modulated starts are not an abborant start proceedure...it's SOP on some aircraft and systems.
If you're getting a slow start and it's trying to climb, using the fuel cutoff to modulate the start and milk it up is far better than either being stuck somewhere, or letting it start hot. It's a legitimate pilot technique, and a necessary one on some engines.
Pilots who are used to plug and play self limiting engines find this unusual, but it's not. It's just that you probably haven't come across it before.
Jockeying the condition levers!
There is usually a bigger problem, if you have to resort to those kind of measures and it would not be approved by Pratt & Whitney.
I've heard of adjusting throttles when you're stuck around, like 40% or so, with a hung start. I guess I'm unclear on whether you're saying it should be done below, say, 10% or not.
No, if you can't get ten percent off the battery, then a battery start shouldn't even be attempted. Any Pt6A ought to do about eighteen to twenty percent on the starter with battery only, before fuel.
Some engines go warm at lower RPM's, say 30, 35, 40, etc. Going to cutoff while the temp drops and RPM doesn't appreciably droop allows one to put in the fuel again, continue with the start, without over temping. It's a pilot modulated start. Some powerplants are throw-the-switch-and-forget, but some aren't. In either case, if the temp is climbing and RPM isn't, before calling a hung start (in which everything should stop, temp included), consider a pilot modulated start to protect from overtemp.
This isn't the same as bumping the power lever during the start. I'm talking about preventing a hot by going to cutofff, the right back to on again. It's sometimes referred to as "blipping." It's either that, or go to cutoff and stay there and let the engine motor. However, if one wishes to continue the start, which may well be preferable, it's a matter of the pilot protecting from over temp. If the engine does overtemp, it's operator error, not the fault of the engine.
Okay, I think I understand you now. I thought blipping below 20% would totally burn the engine up, but you're not talking about that. You're also not talking about getting your secondary nozzles to kick in with a hung start. You're talking purely about temp control.
Does indicator lag in the ITT gages factor into this? Even with thermocouples, it takes a second for the needles to move. Do you target a reduced temp on the ITTs to prevent momentarily overtemping things and shocking your hot sections? Do you depend on the 2 second, momentary ITT limitations?
How does the battery factor into this?
Usually, with an overtemp on the start, we just discontinue the start, clear the engine and try it again. Usually I can get one engine and generator online, so battery power to get the bad engine up isn't an issue. Trying to do a pilot modulated start, as you describe, is something I'd probably foul up. I could see myself waiting a second too long to reapply the fuel and really burning the engine up. Thankfully, my AFM saves my ego with a little limitation that says:
"If starting attempt is discontinued, the entire starting sequence must be repeated after allowing the engine to come to a complete stop."
Just to clarify, when you mentioned blipping the engine with low battery power, you were talking about only having enough batt. to get one solid start out of the engine but not enough to make a second attempt. Is that correct?
Finally:
All of us who post on this site, myself included, think we have something important to say. Combine that typical pilot egos and we get a little touchy when people questions us or suggest something we haven't heard of. We see something that initially strikes us as silly, when, in reality there may be some merit to someone's statement. We also see things that seem reasonable that may be foolish. When I ask these questions, I'm not trying to fight you, or make you look silly. I'm simply curious about a technique which I haven't observed, and perhaps it'll help me get an engine started on a lousy, frigid night.
G-force
They cannot find anyone willing to buy the aircraft,it is in bad shape and needs some good maintenance.
This is what I was referring to by increased ITT limits between the -41 and -42.
[FONT=verdana, arial, helvetica]PT6A-41[/FONT][FONT=verdana, arial, helvetica]850[/FONT][FONT=verdana, arial, helvetica]403[/FONT][FONT=verdana, arial, helvetica]The PT6A-41 is an engine model which features a modified compressor and 2-stage power turbine for higher ratings. [/FONT][FONT=verdana, arial, helvetica]PT6A-41AG[/FONT][FONT=verdana, arial, helvetica]850[/FONT][FONT=verdana, arial, helvetica]403[/FONT][FONT=verdana, arial, helvetica]The agricultural version of the PT6A-41. [/FONT][FONT=verdana, arial, helvetica]PT6A-42[/FONT][FONT=verdana, arial, helvetica]850[/FONT][FONT=verdana, arial, helvetica]403[/FONT][FONT=verdana, arial, helvetica]Similar to the PT6A-41 except for increased cruise rating and increased ITT limits with improved compressor reduced loss exhaust ducts. [/FONT]
i used to love flying 280SC and 22BJ....they both flew like a dream....man i miss those days.
emspilot 02
Sounds like scooter, really misses the good old days of flying junk and not getting paid crap.Most people would rather get out of aviation, than going back to that time period.
To pilotman121
Now we know why these aircraft are junk( N280SC & N22BJ) ,it was emspilot 02 that was hot-starting these aircraft with no GPU, cooking the hot-sections,flat-spotting the tires,wearing out brakes.He has a lot of nerve to be critical of others,I guess DA is paying for his mistakes as well as his current employer.If he could just manage to read a manual and stay out of domestic abuse trouble,he might be able to learn how to start a PT-6 the correct way.
to g-force
well I don't ever remember hot starting a king-air, but i guess we sure know it wasn't you because you never made it to king-airs if i remember right. I will admit i flat spotted a few tires, but my oil caps stayed on and i never broke 2 coffee pots in one day. but i do agree with you that the owner DA couldn't take care of a wet dream if he tried.
emspilot 02
Don't you think that you are being a little hard on G-force.
emspilot 02
How could G-force chase off all the flight nurses?
pilotman121
Both of us know that emspilot 02 is conjuring up stuff that did not happen,I believe it was he and RA that were always hot-to-trot for nurses and the female pilots.They probably thought they were going to get a bj or something.
emspilot 02-Scooter-Scott A.
At least G-force never ended up in jail for his actions!
