Hugh Johnson
- Apr 28, 2004
The A380 is a beautiful plane to fly in all respects... handling, landing, performance, passenger comfort, etc. The lounge area at the back, the showers in 1st Class are a few of the amenities that the B744 can even compare to. This thing rides out turbulence like a cruise ship in a bath tub... It can climb to FL350 immediately after takeoff when at MTOW of 569 Tons. It can land at MLDW of 395 Tons and needs only 1800 meters (5500 feet) and that's only with AutoBrake Low.
It might not be a bad idea to take your own advice. While I'm not here to throw "rocks" at the 380, the B748 is certainly more than a paper airplane on the "drawing board". It's been in flight test for over a year and actually appears to beat the 380's fuel burn per pound of payload. As far as being the expert because you've flown both, I have no doubt that the 380 is light years ahead of the 744 which has, after all been in production now for 20 years. If the 380 wasn't significantly more efficient, there would be something very wrong. As far as showers and bars, those are more functions of the airline that operates them and don't really reflect on the basic design of the aircraft. (I have flown on the 380 and it is very nice from a passenger point of view) Whether it will turn out to be a money maker over time for the airlines that operate them, it's going to take awhile to really see how that plays out.JT8D...
You sound like a typical Boeing guy with a "small package" syndrome....
If you're gonna throw daggers... Make sure you have your facts straight and can back it up.
This happens all the time in the industry and it is what pilots are trained to handle. The issue here is the Rolls engines on the A-380. Qantas has found it can operate no more than 75 flights at full thrust before it needs to replace the engines. Each engine costs $10 million. The flights from LAX to Sydney require full thrust in order to carry a full load of passengers.Oh no! A Boeing with CFM engines suffers engine failure. Boycott Boeing!![]()
