PowerRanger
- Feb 26, 2006
Well, an A320 can weigh up to 170K and has between 44,000 and 54,000 lbs of thrust.
A 757-200 maxes out at 255,000 lbs and has between 73,200 and 87,000 lbs of thrust.
Each airplane has a bunch of engine and weight variations...
A 75-200 with the big motors has a thrust to wt. ratio of 2.93
An Airbus 320 with the big motors has a thrust to wt. ratio of 3.14
Hmmm
Of course thrust to wt. is only part of the equation. Some variations may have lighter airframe wts with higher thurst engines. Airframe aerodynamics is the other, as I have flown smaller jets with lower T to W ratios of similar sized small jets, and the lower powered bird with the better airframe design won out in several areas.
ymmv...
Well that's interesting to read. Everything that I have read was that the P&W and RR engines on the 757 were about 36-45,000 lbs. of thrust.
Definately not arguing with you,just never heard the thrust was so high on the 757 engines!
