Yes....and no.
If you were A/F then you'd never use it for TO/LDG because the book doesn't tell you specifically to do that.
If you were Navy... you might use it because the book doesn't specifically tell you you can't use it for TO/LDG.
If you were/are civilian you'd remember not to turn on your strobes when taking the active with jets behind you.![]()
Coast Guard.... why?
Yes....and no.
For a second there, I thought SWA FO switched names.
Won't go off automatically when the gear is retracted. Forget the switch, the light stays on.
