737 systems question/737 Gear up in Russia
igneousy2
Total Time
100+
Jetliner safely lands with retracted landing gear in Kaliningrad
KALININGRAD. Oct 2 (Interfax) - A Boeing 737 belonging to the KD-Avia airline safely landed with its landing gear up at Kaliningrad'sKhrabrovo airport at about 11:00 p.m. on Wednesday, KD-Avia ExecutiveDirector Leonid Itskov told Interfax. "The aircraft landed with its landing gear up. The fuselage was notdestroyed, and the passengers were evacuated through regular ramps. Noneof them was hurt," Itskov said. "For a Boeing 737, this situation could be called quite normal.Pilots train for it on the ground," he said. The aircraft is designed in such a way that, "in case one of thewheel assemblies fails to extend, all the other assemblies get blockedand do not extend either, and therefore this situation is considerednormal, and pilots are trained for it," he said. The plane was heading from Barcelona and carried more than 100passengers, Itskov said.
Was I asleep during this part of the systems CBT... 1. I don't seem to remember anything about this.2. I don't see how it could be considered "normal"...3. I think I might have missed the day we practiced this in ground school. Kidding aside...should't the gear have been able to free fall into place...I can't think of a situation where NONE of the 3 gears would have released.
Later
Britpilot
Gear Lifter
Total Time
16000
Later
I believe you're correct. Once the locks are released the gear should free fall.
HalinTexas
昇る太陽の土&#
Total Time
10000+
Never been trained to land "gear-up."
Trained for manual (or alternate) extension.
Ty Webb
Hostage to Fortune
Total Time
11000+
Glad to see "Baghdad Carol" Skornica has found alternate employment.
XR650R
Total Time
soloed
Maybe it was a Russian reverse engineered 737. Knowing russian a/c safety records, it is quite possible they consider gear-up landings "normal".
crj567
Answer:
It is Russia. They ain't right-not by a long shot!
jhill
Senior Menber
Total Time
17,000
Later
He's definitely FOS. "A" system pressure releases individual uplocks and hyd pressure extends the gear. If pressure is lost the gear will free fall down. It is not an all or nothing system.
SpauldingSmails
Aboard the sloop.
Total Time
>7000
I seem to remember seeing older video of a USAir 737 (300?) landing with only one main gear down. They land then the spoilers trip and it just dumps.
Oakum_Boy
supercalifragilistic
Total Time
24
They figured if one wouldn't come down, just retract the rest and land on the belly. All quite in a day's work in the former Soviet Union.
