737 Cockpit Companion book
k3mbbc
Hooked on SWA
This question is for those at SWA regarding the 737 Cockpit Companion book that can be purchased at www.fmcguide.com
This may seem silly, but which book cover/binder is recommended?.....the 7-hole with brown cover, the softcover plasticoil (color), or the softcover plasticoil (b&w)?
It's hard to tell the difference on the website. What do most people use?
Don't watse the money. There is no need for it. Read the FRM/FOM. Study the memory items/limitations and flows. Pratice the callouts. That is all you need. You will not need to build the plane. The flash cards from pass737.com....very good. That is all I used. Some people go overboard with the systems stuff.
If you're talking about the Bulfer guide, you should know that he is a scab. If you buy that book then you're supporting a scab.
Anyone who would support a union over supporting their family is crazy!
they give you everything you need don't waste the $$. This is not rocket science. Don't sweat the small stuff you will be fine.
