61 vs 141
Good deal. thank you. I was thinking the single time building would be done before the check rides. And then do some multi traning prior to the check ride for comm in order to get that out of the way first followed with single add on. Therefore after that would just be instruction ratings. Thanks for the replies
Joshrk22 said:
I can't remember correctly but if you get your comm-multi you can't build it in a single like you have stated. You have to build 250 hours in ME aircraft. Everything else looks fine though! Goodluck my friend.
The only thing you'd need in the ME would be the required solo XC (the loooooooong one) and the dual flights (the day VFR/night VFR xc) and a few other things.
You can "build" as many hours as you want SE to count towards your 250 though.
-mini
