$600,000 to spend...
IrishFlyer
Wacky and Waving
I noticed a similar thread in this forum. I need some opinions what you could get for $600,000, the buyer would like to use the A/C for business and for his own personnel use. Requirements would be 6 - 8 seats and a lav. Trips would mostly be in the south TX region with an occasional out of state flight.
Cheers,
IF
Try a 20 series Lear Jet. Don't worry about the lav, you will not be in the air long enough for it to matter.
I'd go with several hundred block hours of charter, if that's the budget. Find a reputable operator.
6 to 8 seating with a lav sounds like a Hawker to me, Nice airplanes but to buy an older one, around 3 million, I could be wrong, yes the maintenace has to be taken into consideration, hanger or not, last time my boyfriend flew a hawker, 350,000 for a required check at Elliot.
The T-bone is an older airplane within your budget and heard you can find one, don't know if it has a lav. Eclipse sells planes for 1 million not too much more than what you have in your budget or just buy the slot and then sell it, you could make money on this deal. Check all possible deals! check every website, and heard you can now buy a 727 sitting out in the desert for maybe 250,000 to 300,000, there is also a website for bidding on aircraft as low as 5 bucks the last time I looked at it.
buy a hawker, may be your best bet!
Good luck
I agree with somedude. With that amount of cash I did think the guy is ready to pony up for what it cost to maintain an aircraft. Those older hawkers and the like are cheap for a reason.
You might be able to buy a 727 for 250,000 but a C or D check can easily run above 1 millon and chances are that is why it is for sale.
Exactly...even at 3 grand an hour, that's a good 200 hours a year of flying. And it's turn-key.
They have MUCH better options than buying a plane and setting up a flight department.
The savings by NOT having at least 2 or 3 employees on the payroll, plus maint, ect...
They are WAY better off buy a block of charter.
$600K isn't enough for six to eight seats and a lav on anything that isn't very old and very expensive to operate.
A DC-3 would do it, hire pilots who are also A&Ps.
$600K is a tough number to work with. I've been helping my old boss with a similar search for nearly 2 years. It's an exercise in futility. He recently upped the budget to about $1.6mil after realizing how much maintenance is involved in buying an old POS airframe. Now we're looking at well maintained B200's and TBM700's.
$600k no problem
Hello!?!? You don't sell a guy with a $600k budget an old p.o.s. jet that will cost a fortune to keep in the air. With most flights within the State there is no reason to fly any kind of jet at all. With that budget he can buy the VERY best 421, 414, 685 Twin Commander, Chieftan, etc. All of these fit his needs and he would have change left over.
DO328FLYER has your answer.
I'd listen to him and look in that direction. You'll be pleasantly surprised at the options available to you. The first place I'd call is Colemill (I don't work for them) and ask about a Panther conversion.
Cheers,
IF
Cessna 402 with a Little John & Lady J adapter
Your all set!
