4-letter airport identifier as an IFR enroute nav fix
hawkerflyer
Can a 4-letter airport identifier be filed (or is it legal) as an enroute navaid on a flight between 2 airports under IFR, or better yet, can it be issued as a clearance. For example from KSDL to KCLT: SCOT6.ABQ..KOJA..VXV.SHINE5. Even with GPS/RNAV equipment onboard, I don't see how it can be. Nothing in the AIM or pilot/controller glossary, looking for written proof as a source to settle a bet.
I say no and I bet you a $1 million that the FAA HOST computers would reject a four letter airport ID in the route field of a flight plan. Finding it in writing will be a pain I bet.
Try ICAO Doc. 4444, Appendix 3 or search the ICAO Flight Planning sites on FAA.gov.
Good luck.
I say 'no' also. I've NEVER seen it...but I haven't tried either.
I don't know about FILING it, however one time I was IFR and a MOA became active and ATC said "tell you what, do direct KABI for now then after you cross KABI cleared direct destination"
so...
I would also say no because I wouldn't think an airport could technically be used as a fix. It has to be a navaid, route, or intersection to qualify. At least as far as I know.
Thanks everyone. I also say no. You can file it but in fact, the FAA computer will kick it back as an invalid waypoint or as a set of lat longs but not as a 4-letter ID. Heard a clearance given to a regional in Canadian airspace that had an NDB in it. The pilot came back and said "we don't have that NDB in the database, can we use the associated airport identifier? ATC hesitated and said sure". At the time I argued with my colleague that it was an illegal clearance but he said he thought it was legal.
with all of this said, a workaround to filing the airport as enroute fix could be a marker beacon/etc on the ILS at that airport
Good luck.
I'll gladly accept that bet, and you can mail me the check for $1 million tomorrow, please!
Haven't you ever heard ATC say, "Cleared direct destination airport"? People do that all the time.
So are you saying you can navigate direct to an airport only if it is your destination?
I say wrong. You can use an airport as an intermediate fix, you can also make up a fix if you want to. Some small airports aren't in the ATC database and you hear ATC asking for lat long all the time from pilots so they can enter that airport as a fix.
What I can't believe is that the regional pilot the OP referred to even asked ATC if they could navigate to the airport instead of the NDB. The implication is that they are co-located, in that case what's the difference? Do you think ATC really cares if you are navigating to a fix that is a couple hundred feet from the one they intended? How would they or you notice the difference? You can also pull out the AFD and enter the lat long in the database if you want.
Ill put in a test flight plan in the FDIO today at work and file an airport as a fix and see if it spits it out.
Let you know later.
MK
I'll try filing a four letter airport in a flight plan route tomorrow at work to see if it gets rejected.
If it doesn't get rejected, I'll send you the rubber check.
http://yfrog.com/ndunfmj
Well, here is how it worked out. I created a test flight plan at work with a flight departing O'hare going to Denver. We used ORD IOW OMA KDEN at it worked fine. As long as you don't use KOMA but OMA it works. The Omaha VOR is OVR and is 11 SE so this was a good test subject. You can file the airports as enroutes provided you file them as 3 letter and not 4 and will not confuse an airport with a VOR on site as it should be the same identifier.
4 letter was a no go! 3 letter was a go!
Bill, send me my check.
FDIO != Host.
It works in HOST, I can get my buddy to try and take a pic/send me a copy of one. 3/4 letter is interchangeable in HOST.
I don't even see any pads on LRJetcaptains strip!
