2nd Haul loss in 2 years
kilroy
http://www.filecabi.net/v
********************************************************************************** Report created 5/26/2006 Record 10 **********************************************************************************IDENTIFICATION Regis#: 475AT Make/Model: WW24 Description: 1124 Westwind, Westwind 1/2, Sea Scan Date: 05/24/2006 Time: 0500 Event Type: Incident Highest Injury: Minor Mid Air: N Missing: N Damage: UnknownLOCATION City: MOSSTOWN State: Country: BSDESCRIPTION N475AT, AN AIRTREK WESTWIND 1124 ACFT, DECLARED AN EMERGENCY WITH AN ELECTRICAL PROBLEM, EIGHT PERSONS ON BOARD, ONE SUSTAINED MINOR INJURY WHEN EXITING THE ACFT, DIVERTED TO MOSSTOWN, EXUMA, BAHAMASINJURY DATA Total Fatal: 0 # Crew: 2 Fat: 0 Ser: 0 Min: 0 Unk: # Pass: 6 Fat: 0 Ser: 0 Min: 1 Unk: # Grnd: Fat: 0 Ser: 0 Min: 0 Unk: WEATHER: NOT REPORTEDOTHER DATA Departed: SAN JUAN, PR Dep Date: Dep. Time: Destination: PUNTA GORDA, FL Flt Plan: IFR Wx Briefing: Last Radio Cont: Last Clearance: FAA FSDO: MIAMI, FL (SO19) Entry date: 05/24/2006
Hard Landing
T-Gates said:
Where in the report does it say they totaled the airplane?
The report is not even close to factual. They had a dual Gen failure at 12:30am coming out of TJSJ when it happened. They tried to get into the nearest airport but unfortunatly the local authorities could not find the keys to turn on the airport lights.
They attempted a landing in the middle of the night with no runway lighting and no aircraft lights. Landing extremly hard and over running the runaway by 500ft they ripped off the right landing gear and right tip tank twisting the fuselage. The imapct was so hard it ripped the throttle cable from the right engine leaving the engine to run all nigh long at a high power setting. The next day the finally got the engine shut down.
kilroy said:
The report is not even close to factual. The imapct was so hard it ripped the throttle cable from the right engine leaving the engine to run all nigh long at a high power setting. The next day the finally got the engine shut down.
What? They couldn't shut the engine down with the fire/T Handle?
Something not right with this story.
The T-handle actuates a electrically controled solenoid (Firewall Shutoff)shutting off fuel to the engine with no Battery or Gen there is no way to get power to close the firewall shut off. The only mechanical link is between the throttles and the engines. $hitty system. .
