Quote of the month! Ha ha ha ha ha ha!!!!!So pu$$ys fly Jetstars?......I thought they flew Legacys?
What's a Jetstar?
If the Falcon 50 has "low DOCs," then so does the Legacy. If it doesn't, then neither does the Legacy. C&D has them within $50/hour of each other.
You say that the Legacy doesn't break, etc. If that's so, why do you harp on the fact that it has a good MEL? BTW -- in the last seven years, I think that I've had to MEL something once. The number of times that I couldn't MEL something? Once as well. It was due to a failed starter/generator, and delayed us all of two hours.
Cabin size -- For comparison, let's stick to the large cabin Falcons. The cabins of the 900EX, 7X, and Legacy are all within 150 cubic feet of each other.
Affordability -- Mid 2000's Legacy's are going for the very low $10m range, or below. So as far as acquisition cost, yes, the Legacy wins. That said, the DOC's of each aircraft are within $150 of each other, so I'd have to say that as far as operating the aircraft, it's a draw.
Redundancy, I cannot say much about, as I am not familiar enough with the redundancy offered by the Legacy. They're all Part 25 aircraft, so to a certain extent, the redundancy has to be similar.
Reliability -- You talk like corporate jets break all the time. The reality is, they don't. In my career, I've had one aircraft break that resulted in an extra night stay. Fact of the matter is, just this week I saw a Legacy be AOG with a flap problem. The airplane that used to be based in the hangar next door was broken at least three times that I know of. Using those stats, and the dispatch reliability numbers published, the Legacy is less reliable than other corporate jets, not more.
Again, corporate aircraft don't break the way that you claim that they do. Regional aircraft, airline aircraft, etc. that's a different story. I think I've rode the airlines about ten times in the last five years. Of those times, I've had two delays that I can recall due to a mechanical issue. In that same period, I've had zero delays while on corporate aircraft. These stats don't support your statements indicating that corporate jets are unreliable.
LD, the reality is, you have a limited amount of corporate experience, and most of it being in very mediocre to below average jobs (opinion based on how you've described them; I have no personal knowledge of any companies that you've worked for). You have formulated opinions based on your limited, mediocre jobs that simply are not in line with reality. To me, your love for the Legacy is bizarre. The only thing that I can think of is that you simply don't know better...
This argument of my aircraft is better than yours, is not only not realistic, it is not logical as well.
The best aircraft is the one that provides the highest salary and the best QOL.
Rather simple really.
I didn't think we were talking pay, but were talking aircraft performance?
But in reality performance tends to go along with the cost of the aircraft?....more expensive usually happen to pay better?....and often better QOL?
Off your meds again?
"Usually."
But I made more as a charter Legacy Captain than my buddy flying the 900EASy as Captain for a non-Death Star mega-corporation. And my QOL made his look lame by comparison. Unless you consider 14 days in a row away from home QOL. I never did.
If a Cessna 152 has the same cost per hour as a C-5 Galaxy then ONE of them has a high DOC and one has a LOW DOC.
That the Embraer is like ten times the size of the 50EX for the same fuel burn means the LEGACY is more efficient. It's really simple you know.
Because it has to break REALLY flippin' bad to get stuck. The MEL is great so even if it breaks I can go.
Then the Legacy isn't such a POS after all.
Not even close. The EMB equipment list beats anything out there.
It is built like a tank and has redundancy coming out of its ears. There are plenty of Part 25 airplanes that don't have the redundancy of the EMB. You used to fly one in fact.
Again, your "stats" are parroted off an article by Clay Lacy from years back. They are not the actual numbers.
(BTW, the Falcon 7X has a whopping 99.7% rate. I also enjoyed the BCA article this month that mentioned the survey results on the 7X: crappy brakes, wimpy rudder, and horrible nose steering. ROTFLMFAO!)
I checked with my sources on your alleged broken EMBs. They tell me you have bad info. Just like that crew that told you they were weight limited out of Carlsbad. They weren't.
You have no idea my experience. You don't know all the different places I've worked as a contract pilot in the Corporate side. And unlike you, I've flown planes built by your manufacturer (and flown even the same type in some cases). You've never flown mine. So I would say the one who doesn't know better is you.
