1st, 2nd, 3rd and Final Climb Segments
RJFlyer
Wastin' time...
I know I read about and memorized the definitions of 1st, 2nd, 3rd and Final Segment Climb long long ago, but can't for the life of me remember the definitions and details, and can't find it in the FAR/AIM.
Any help?
Thanks!
I'm sure I'm missing something and I'm sure someone will let me know, but:
1st: From takeoff to gear up at constant V2, with T/O power
2nd: Gear up to level off, again at V2, with T/O power
3rd: Level, accelerating to Vfs while retracting flaps, with T/O power
Final Segment: At Vfs, 1500', gear/flaps retracted, max. continuous power.
1st seg. Starts at 35' above runway at V2. Extends to height at end of gear retraction. Postive climb gradient. Constant V2 speed.
2nd seg. Gear is up. Constant V2 speed. 2.4% minimum climb gradient.
3rd seg. Starts at no less than 400 agl. At t/o thrust accelerate to final segment speed (V2 + 5) while retracting flaps.
Final seg. Maximum continuous thrust to 1500' agl or 35' clearance of obstacle
Climb gradient of 3rd and final segments cannot be less than 1.2%
It won't be in the FAR/AIM. It has nothing to do with regulatins or rules.
It deals with aircraft certification - what the airplane will and won't be able to do - not the pilot.
It it covered under Part 25.
Not to be a d!ck but...
...that's kind of a contradiction isn't it?
"...nothing to do with regulations..."
"...covered under Part 25..."
-mini
And this is both engines, or single-engine climb?
Thanks for the info!
deez_nutz2000 said:
I really hope you are kidding, seeing that you fly an RJ and all.
These are details that I've learned in the past, haven't used in several years (the definitions of climb segments, that is) and have since forgotten. In the RJ, we have something called a Runway Analysis Manual. It tells us everything we need to know in regard to how heavy we can be to take off on a given runway at a given temerature and flap setting, or whether we can at all, and it's predicated on the most limiting of several factors, one of which is single-engine climb performance. Nowhere does it mention or require knowledge of the definitions of climb segments. I couldn't remember and couldn't find it in the FARs, so I asked. So bite me.
I agree with some of the other assesments RJflyer. There is no reason that you should not know the most basic of elements such as this. It is unacceptable to "forget", that is why they create these things called books. What one does is that they read them every once in awhile to make sure they have not forgotten such simple elements such as this. I find it extremely inexcusable that you fail to do your job.
Seems that nobody can come here and ask a question without being gutted and fried. That's too bad.
The engine out climb gradients specified in Part 25 are designed to ensure that aircraft certificated under that part can still meet minimum performance criteria with a partial power loss; this regulation is intended to meet a higher standard than that prescribed in Part 23.
Both Part 23 and Part 25 prescribe a great deal of technical information, formulas and technical requirements, that few people will ever memorize. What the minimum certification climb gradients are is really quite irrelevant. You do not need to memorize them. Doing so certainly doesn't hurt, but don't be so fast to beat someone up because they didn't have that information at their fingertips.
You might recall that even the FAA is more interested in weather you can find the information, than weather you know it all...and certainly would rather see someone admit they don't know it than someone try to bluff their way through.
When considering climb gradients, the only numbers of any significance are real-time numbers. In other words, what will this aircraft do right now, at this elevation, at this weight, at this temperature, in this wind, with these runway conditions. What the aircraft did for certification is unimportant. What can it do right now?
Accordingly, we calculate every takeoff, every landing, and plan for the book performance. Your AFM performance section should include climb gradient and rate of climb information for both all-engine operation, and engine-out operation. You should calculate both. However, if you calculate performance with an engine out and find that it can meet the climb gradient criteria for the departure in consideration, then it's a cinch that you will easily exceed it with all engines operating.
Some of you guys seem to just wait in the wings looking for the wounded, so you can attack. Give it a rest, already.
-mini
Well yes and no ........even though he said that it "has nothing to do with regulations", he did say it wouldn't be in the FAR/AIM. What was probably meant was that, "it has nothing to do with [standard operating] regulations". If you haven't learned this yet (I am being serious) the FAR/AIM is only a small segment of the entire CFR.
........and I have to agree with Avbug.....I regularly preach "never stop studying and learning(and relearning if necessary) but I'd like one of you Uber-Pilots to describe to me how thorough memorization of the exact specifics of the climb segments is going to assist you beyond what you have already referenced in the AFM regarding that specific takeoff on which an engine does fail?
Eh, lighten up Francis.
Knowing the precise definition of each segment of takeoff has nothing to do with the safe conduct of flight, and I suspect few airline pilots could give you a correct unrehearsed answer. It's something you learn for the ATP written & possibly freshen up on for prochecks. Not everyone has a copy of FAR 25 in their back pocket, so RJFlyer was being perfectly reasonable by "using all his resources" and asking around here.
As for me, I study the FSM and Ops Manual a few hours every month to stay fresh, but if it isn't something I need to know to stay safe and legal, and I have no great curiosity to satisfy, I don't waste time.
