LowlyPropCapt
PBR For Life, and Beyond!
- Jul 14, 2005
Again though.....they never reported for duty. It doesn't matter if they were drinking up unitl 4 hours prior to duty-in, if the called in sick they can't do anything...the never reported for duty. Now, there may be some sort of behavioral/morality clause in the company manual that they could get them on, but unless they actually went to work over the limit they can't get in trouble for that. ALPA has fought that battle numerous times and gotten many folks there jobs back with lost pay.
Let me tell you a story. At my company about a year ago, we had a pilot who showed up at the airport that smelled like alcohol. A TSA agent discovered this and reported him. The airport police made him take a breathalizer test and while I don't remember what the exact result was, I do know that he was below FAA limits but was above our company's more restrictive limit. An investigation proved he had not had a drink within the FAA and company 8 hr rule. So his only violation was breaking the company policy of blowing too high a breathalizer score.
So what happened. He was fired by the company but a statement by our FSDO (the statement was published in the newspaper; I read it) was that he didn't break any FARS; he broke a company rule and it was a company matter so the FAA wasn't going to pursue it.
So tell me; You have a Fed in the jumpseat and your company SOP (FAA approved, right) says you're suppose to climb out at a certain speed but you climb at a different speed and violate company policy. There's no way unless you break a FAA speed restriction (ie: more then 250 below 10, ATC instructions or crossings), that a fed could violate you for that. A check airmen could whack you on that, on a linecheck or a checkride but there's no FAA violation here even though the FAA signed off on the SOP.
But then there's that "careless and reckless operation" thing they could get you on in certain circumstances I guess. But I think you all get the point.
Sadly, I don't think it would surprise any of us if it existed...
I don't think the Feds can or will do anything. As has been stated, they never actually reported for duty. What actions the company takes is another story.
I see it that way too. Although they may not be able to get you on the company's 12 hour rule, that's not to say they may not try pursuing a wreckless/careless charge.
Now I've also heard that just putting the uniform on could be enough to show intent. So if you're driving to the airport and get stopped a block away and get busted for failing a breathalizer can the FAA violate you if they could show that you would of shown up to work within 8 hours of drinking if you hadn't been stopped?
Absolutely wrong, when the companys rules are more stringent than the FAA's, then the FAA will adopt those company rules for their employees, so at TSA and most airlines the FAA requires 12 hours.They didn't violate any FARs, so no FAA action but would probably get fired from TSA for violating company policy.
No, they can't. MY company has an EIGHT hour rule, and I use it all the time. Nobody ever tried to accuse me of "careless and reckless" for drinking less than 12 hours out
:beer:
it is a class B violation, it is not a violation the FAR's but it is a violation of a written FAA apporved procedure. The company will have to show it is taking action to correct this, but there will be no fine or violation. Just a letter of correction. Based upon my experience, not drinking, with a mechanic doing an engine run-up without completing company training.The "mooning pilots" made it onto the first few minutes of Inside Edition the other day and at the end of the report they mentioned that the two might have been drinking inside of TSA's 12 hour rule. My question is if they were found to be drinking within 12 hours, but outside of 8 hours can the FAA enforce any kind of certificate action? Obviously if they were drinking within 8 hours then they would have violated the FARs and certificate action would most likely follow. If someone is found violating a policy in their companies GOM can certificate action follow?
Correct. As far as the FAA is concerned, there is no way they could prove the pilots were going to go to work the next day...the FAA would lose the case on appeal, so why bother?
The company is in the same boat...they can't punish the pilots for violating the 12 hour rule, cuz they did not go to work.
They can punish them for a schedule deviation which is probably not a firing offense for non-probation pilots. If they try to fire them for a 12 hour violation, the pilots will just claim they lost track of time and would have called in unfit when they realized their "mistake".
All manuals are written different but unless you have changed or eliminated your show time you can still be tagged for violating your companies 8-12hr alcohol policy. Within a 12 hour period prior to an assigned duty period. No room for just calling in sick before you get to the airport. And you can and will be tagged for an opp's if it's inside 12. A few people have diappeared for this. This is blunt but this is what has happened in the past.
