Cons: After paying the ZED charge and the taxes they can get to be pricey. Must purchase them from your own companies ticket counter. (your outta luck if you need to buy one in Cairo or Bali) Many foreign carriers do not recognise "travel companions" or Dom. Partners if you are single.
Umm... I don't think they're refundable. You're thinking ID-#'s.
ZED fares come in Low - medium - & high.
Depending on your airlines agreement with the other airline you will fall into one of these 3 categories.
Most overseas airlines requi re at least 6 months of employment; however, for the correct fare and charges you MUST check your own airlines agreements.
Low is close to ID90, Medium close to ID75, and High is ... well you might as well by a ticket.
In order to be able to use one ticket issued for airline X on the same route for airline Z, the fare agreements must also be on the same OR a higher cost level. Med will cover Low but Low will not cover a Med.
Some airline are good and don't care to much while others stick to the letter of the agreement.
:cartman:
