Gotta go with Bobby on this. ("hinky"?)bobbysamd said:I think what I would do is henceforth be conservative and use the criteria above to count your cross-country time and not correct your logbook. All of a sudden adding time that was not there before will look hinky and, worse, perhaps draw unwarranted attention to your logbook.
Not quite. Here's my FAQ on the subject:KickSave said:Do I understand this correctly, that for the purposes of the Commercial Pilot Required Experience, the 50 hours of Cross Country needs to be to airports located at least 50 nm away. But once you have your Commercial license, with regards to the 500 hours Cross Country needed for the ATP, you can log every flight that lands at any other airport (even ones 5 or 10 miles away) as cross country time
I suspect primarily because it counts for =technically= meeting 135 requirements. Here's an example.KickSave said:So then the question is, why would someone log as X-C those times when they went down the street to practice touch and goes? It won't help for a rating of any kind, and it seems a prospective employer would hopefully not be impressed by someone with 1300 hours X-C time, in only 1500 hours total, and they've rarely ever even left the county they live in?
This sounds like the best way to keep track of your point to point time. Would you include your 50nm+ time in that column too (making it a total X/C column)? I'm thinking about using your idea to keep track of pt to pt time but it seems that the point to point time is only important for a 135 job, meaning it won't help you with the ATP rating. Is this correct or to I need to go back and read the regs again?As a student I began logging only 50nm airport to airport flights as XC. Now that I am nearing my ATP and exploring 135 opportunities I created a column in the back of the Jepp Professional Logbook month by month experience section for point-to-point Cross-Country. I went back through my training and added up any flights that included another airport.
