Paul R. Smith
Fender Bender
- Jan 15, 2004
This, too, is likely to be based primarily on duty day rather than as it is now, primairly on block to block times.Rounded, this is about
8 hours of duty (not flight time) per day in 7 days,
7 hours of duty per day in 14 days
7 hours of duty per day in 28 days.
This is what may drive greater numbers on the pilot rolls. Right now, you put a reserve out on the neverending gobstopper trip, you will likely run up against this stop, vice a 30 in 7 stop. Six days of flying, allowing for only 55 hours of duty time, gives you about 9 hours per day of duty. Add show times, sit times, on call times (which count in this reg as duty) and probably will hit 55 hours of duty before you hit 30 hours of flying. That reserve has to go home and rest. And this rest isn't 24 hours from from duty anywhere in the world, anywhere on your circadium clock. It is:There may be some efficiencies gained by being able to fly 9 hours, but many of the other restrictions I think will more than offset this.
And the above is basically for daytime trips. Once you get into night stuff it gets even more restrictive.
I dunno, I appreciate your logical and pragmatic assumptions but with airline stocks up today, I think the CEOs at the airlines are salivating about the future of pilot staffing as it is impacted by the FAA's NPRM.
They know something.
