MarineGrunt said:Now is it enough to make a difference to your 172 if you fly through the wake of a 757? I seriously doubt it....
That was my point....I was trying to make a very very tongue-in-cheek comment.
-mini
Ah. I thought you were speaking in broader terms. I can be slow somethimes.............. (to the surprise of many!)minitour said:That was my point....I was trying to make a very very tongue-in-cheek comment.
-mini
MarineGrunt said:Ah. I thought you were speaking in broader terms. I can be slow somethimes.............. (to the surprise of many!)
AirBud said:There was an article about this 3 or 4 months ago. The wake on the 757 is reduced by something like 30% with the winglets.
Check out
http://oea.larc.nasa.gov/PAIS/Concept2Reality/winglets.html
Langley researchers were constantly challenged by the complexity of the wake flow field for representative transports. Many concepts that appeared to affect the wake properties in the immediate roll-up area behind the generating aircraft were found to have little impact on the magnitude of roll upset at downstream distances representative of the location of trailing aircraft. Furthermore, it was found that numerous interacting vortices were shed by the typical transport in the landing configuration. For example, in addition to the vortices expected at the wingtips, strong vortices were also shed at the edges of wing trailing-edge flaps, and aft fuselage. As a result of these types of interactive vortex effects, some wingtip vortex control concepts that were known to provide beneficial effects for cruise drag (such as winglets) had little or no effect on the wake vortex hazard when the aircraft was in the flaps-down, landing approach configuration.
