Windshear on T.O
uwochris
Flightinfo's sexiest user
Hey guys,
Why is it recommended that if there is windshear on takeoff, you should use a high pitch attitude close to "stick shaker"? To me this seems unsafe- ie) you'd be close to stall, and if there is windshear, the risk of stalling is high.
Thanks in advance.
The risk of slamming back into the ground is greater.... A severe windshear encounter is an emergency situation that you must use every ounce of the aircrafts performance to stuggle out of it. If you get stuck in a 3000-4000+ Foot Per Minute down draft you really dont have any choice but to get that nose up and ride the shaker to get every thing possible out of the aircraft.
I was taught and agreed with your above statement until I got my type rating in the Falcon 50EX.
At both Continental Express and American Airlines we were taught the standard pull up and hold it till the shaker starts. I thought that was the gosphel in regards to Windshear until I went to Falcon school.
Dassault sees it a little differently. They suggest that you keep your nose level with the horizon and try to get out of the windshear as fast as possible. At first I thought that they were nuts but then I tried it in the sim and it works really well. If you are pitched up say 20 degrees and flying 130 knots across the ground it will take you alot longer to get out of the windshear than if you are pitched closer to the horizon but going 250 knots across the ground. You might be losing quite a bit more altitude but again you will fly out of the shear faster.
The theory is the same as what I do when I am flying my glider. When I am in very very nice lift I fly L/D, 1 knot above a stall to maximize my exposure to the lift in the thermal. HOWEVER, when I am in heavy sink I fly as fast as I can to get out of it.
Like I said I thought those folks at Dassault and Flightsafety were nuts but after doing it in the sim I am beginning to question if pulling up to the shaker is always the best way to escape.
Not saying one is better than the other just thought I would bring this into the discussion.
I've heard the above, about flying fast to get out of the shear...but IMO, it is better to fly the shaker. You just don't know how fast the shear is sending you downhill nor do you know how big the area of the downdraft is, and if you are just after T/O, you are less than 1000' AGL and you need every foot you can get. Putting the nose down might work better if you have some altitude to work with, but close to the ground, pitch up and maximize your aircraft's performance.
Wow, at 3000 or 4000 FPM in the PA32 or M20J that I fly I guess it doesn't matter. Dirt sandwich for me.
I understand why you are confused as to windshear escape maneuvers which dictate flying to the stickshaker. However, I can shed some light:
The obstacle-avoidance procedure we learn in primary training is to fly at best-gradient-of-climb (Vx) to climb at the steepest possible angle. So it would seem that to avoid hitting obstacles, Vx would be the best airspeed. It is not.
If a pilot maintains Vx, that will yield the best possible gradient when compared with maintaining any other speed. But a pilot who pitches up and decelerates through Vx and continues to decelerate will climb at an even steeper gradient. The concept of Vx only applies to a steady airspeed. A decelerating pitch angle will exchange airspeed for altitude while the airplane decelerates.
Thus a plane encountering windshear can exchange all available energy for altitude by pitching up to the 'shaker, thus exchanging all available airspeed for altitude.
Thanks for all the replies!
Should pilots, however,not be conscerned about encountering a strong updraft at such a nose-high attitude, that a stall could result?
The primary area of concern is a microburst encounter, and this can be avoided by not taking off under or close to a thunderstorm, or approaching to land near the same.
In some locals, dry airmass thunderstorms or dry microbursts can occur without the traditional appearance of a thunderstorm.
Blindly pitching to the stall warning or stick shaker is the wrong choice, but pitching with power to avoid ground contact is the right choice.
Don't get any slower than you need to as you cross the region of greatest vertical gusts. How much you need to pitch and how long you need to hold it depends entirely on the nature of what you encounter. You may not have the capability of flying level to get out of it...but you may.
I've encountered a microburst both on landing, and on takeoff, that required continuously pitching to avoid ground contact, and then not by much. In other cases, particularly in rapidly changing conditions in mountainous areas, I've encountered microbursts or descending air which permitted a rapid transit without an uncomfortable loss of performance.
Deal with what you get at the time with what you must, sacrificing no more airspeed or altitude than you absolutely must. Don't forget, you're going to wind up on the downwind side of it, and arriving there low, slow, already far behind the power curve, and out of ideas, is not the best place to be.
I agree...I had this discussion with the my last couple of sim instructors. One said I should go right to the shaker as soon as I encountered the downburst, the other saw what I was doing and approved to start with.
My position was that I didn't want to trade all my airspeed for climb too early. If I used up all my energy at 500 feet, I'd just accelerate towards the ground on the shaker, and if I hit the ground I'd hit hard. On the other hand, if I maintain some speed until I'm closer to the ground, and find impact unavoidable, I can make my energy trade so as to minimize my descent rate when I hit.
If impact is inevitable, I want to hit as softly as possible ;)
Fly safe!
David
At my operation, when I was hired they were teaching the windshear maneuver in the usual pitch up, ride the stick shaker, etc. Within the past year or so it has been changed to pitch up to V2 instead of the previous way.
Wow! In all the training I've had at FSI on the 2000 and 2000EX EASy, at no time was I taught to lower the nose and try to race out of it. In fact, in the 2000EX EASy CODDE2, section 03-15-20 "WINDSHEAR," the first action is to:
"PF should disconnect AP and AT, level wings, pull up to stall warning onset and maintain FPV just below the AOA limit symbol, sets engines at Take-Off and airbrakes to zero."
This is the standard windshear escape maneuver for both take-off and approach.
Danger Kitty,
It would take a lot of balls to pitch towards the earth during windshear. Did they say this technique was assuming a windshear encounter of known dimensions? How do you really know you are going to exit the windshear area before you are forced to the dirt?
Not to take away from your comments at all, that's a different way of looking at windshear and it certinly has some merit. But, I wanted to point out that the fact that something works in a sim doesn't necessarily prove anything either way. Sims of course are an approximation of reality. True, some are really good approximations of reality, but they all have thier limits.
When you use this manuver you probably have some altitude to work with and are not less than 1000' AGL.
When did FSI start to teach this procedure? I've been to 1 initial and 4 recurents on the 900 and have yet to be taught this procedure. The only thing that I remember beign different from what I have been taught in the past is that Dassault tells you to raise the landing gear in a windshear. Every other manufacture says to leave the configuration alone until the aircraft is flying.
Furthermore, I can't imagine pushing the nose over to get back the 10 -20+ kts of airspeed that I just lost on takeoff when I'm only a few hundred feet off the ground. You are already in a situation where you may have a sink rate that you cannot recover from. Why would you want to push the nose over and increase that sink rate.
From what I remember from training many years ago is that, you pull the nose up to stop the sink as needed, and if necessary up to stick shaker always respecting stick shaker. This gets the wing pointed more into the relative wind from the down burst increasing lift.
I'm curious as to who the FSI instructor was that taught you this procedure. Big Al isn't teaching the 50EX also is he?
I think there may be some confusion here
Most manufactures that I have flown recommend pitching to 15 degrees nose up and holding that through the entire encounter. The shaker should not deter you from maintaining 15 degrees as the target but the shaker is not the target. This goes for Boeing and Mcd.
Same here
From our FOM:
Disengage the autopilot and autothrottles.​
Aggressively advance the thrust levers to the mechanical stops and call “Firewall Thrust”.​
Simultaneously roll wings level and rotate to an initial pitch attitude of 15 degrees. (Pitch attitudes as high as 20 degrees may be required to silence the “Pull Up” warning and/or avoid terrain.)​
If the vertical flight path or altitude loss is still unacceptable, smoothly increase pitch attitude in small increments (2 degrees) until an acceptable flight path has been achieved.​
Respect stick shaker. Use intermittent stick shaker as the upper pitch limit.​
Maintain gear and flap position until windshear and terrain clearance is no longer a factor.​
Accelerate to maneuvering speed, call for climb thrust and resume normal procedures.
[FONT=Arial,Bold]
NOTE:​
[/FONT]Do not use flight director commands.​
Just got back from 900EX recurrent at FSI TEB. The excape maneuver is leave flaps and gear where they are, firewall the throttles, pitch up and ride the stick shaker/stall warning system until you exit the windshear. Period, end of sentence.
The 900EX has some operating differences from the 900A/B even though they are the same airframe. I can't figure out the French.
Not to change the topic of the thread but, does the 900EX have publised X-wind limits for wet and slippery runways?
Supp 2 of the performance manual, operations on contaminated runways, has a limitation of 5KT on "icy" runway. It defines icy as "contaminated by ice", "A runway surface condition where braking action is expected to be very low, due to the presence of wet or dry ice."
As I understand it the stick shaker is max L over D. This is based on Angle of attack so it is the most accurate.
One thing I have noted when studying windshear accidents is the last thing on the voice recorder is " watch your speed" (In all cases they were slow as one would expect in windshear) As is our habit when we see a slow airspeed we want to lower the nose to prevent a stall. This is where they all released back pressure - lowered the nose and the airplane crashed into the ground..... most experts seem to believe if they had maintained their attitude they would have flown out of it.
The ERJ has 2 windshear escape modes ---
Yellow (increasing performance) calls for immeadite go around and reconfigure (gear up, flaps 9) There is a WindShear flight guidance mode but in this case it only comes active with the TOGA buttons.
A RED windshear (decreasing performance) call for immediate go-around with out re configuring and that flight guidance is set up for max performance... it is not necessarily "riding the shaker" in an severe encounter in the sim it seems to be going on and off a lot.
Either way the best protection you have in a windshear situation is to get your self as far from the ground as quickly as possible... in a severe down draft lowering the nose to increase ground speed will get your self killed.
Thing a severe downdraft can be upwards of 4000 fpm (really bad case) you need to find 4000 fpm of climb just to stay level!
I'm going to have to go ahead and kind of disagree with you on that....yeah...Windshear Escape Guidance mode will come on automatically any time it detects decreasing performance. It will also come on when the TOGA buttons are pressed in the yellow windshear mode.
